22965 Discussions
i7-8750H Integrated Graphics on Asus Laptops
fferr3
I recently bought the ASUS ROG STRIX GL703GM, but i'm unable to use quick sync acceleration without the integrated graphic hd630 (i can't enable it in the bios). has to be a way..(the display does not have g-sync but the laptop doesn't have optimus)
Hello FrancescoFe,
Thank you for your joining our Intel ® community.
Based on the brief description of your issue, we noticed that your system is running under Hybrid graphics between your Intel® HD Graphics 630 and your NVIDIA GeForce GTX 1050 Ti.
In this case please make sure that both graphic controllers are enable on the BIOS, as the Intel® Quick Sync is already on and fully supported in your CPU.
In order to provide you further details, please provide me with the report generated by our https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 Intel® System Support Utility for Windows*
To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
Also, please consider:
-The BIOS needs to be latest for the motherboard
- The Windows build should be updated to the latest
- Update the graphic drivers (OEM) to the latest based on your system model.
I hope to hear from you soon.
Diego Sanchez Campos.
Intel (R) Customer Support Technician
Under Contract to Intel (R) Corporation
Hello FrancescoFe,
We just wanted to double check if you need further assistance?
Diego S.
