Hello egorslim,
Thank you for posting on the Intel️® communities. We understand that you are having issues with HDR on your laptop.
- Are you able to enable HDR options on your Operating System?
- Does the issue persist if you disable one of the GPUs (integrated or discrete)?
- What is the projector model?
- To further investigate this matter, we would like to have more system information. Please provide us with the report using the following tools:
- Intel®️ System Support Utility (Intel®️ SSU):
- Download the Intel SSU
- Open the application and click "Scan" to see the system and device information. By default, Intel®️ SSU will take you to the "Summary View."
- Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
- Intel® Graphics Command Center:
- Open the Intel Graphics Command Center
- Navigate to the Support tab
- Select System Diagnostic
- Click Generate Report
- Select Save and name the output file.
Jean O.
Hello egorslim,
We hope you are doing fine.
Jean O.
Hello egorslim,
Best regards.
Jean O.
Hello egorslim,
Best regards.
Jean O.
