23269 Discussions
intel g530 nv12(dxva) vs. yv12 output
G530 with h61
Win7 sp1 x64
Graphics driver version 15.22.54.64.2622
Potplayer x64 1.5.32007
Please click the picture to check it.
nv12
dxva
yv12
What problem ?
Driver bug or other?
thx.
DArce
Valued Contributor III
We would like to better understand the issue you are reporting. It would be very helpful if you could include more detailed information about the problem you are experiencing and any steps you have performed to replicate it and tried to solve it.
In addition please copy-paste the graphics report generated within the Intel(R) Graphics User Interface. For information on how to retrieve this report, please visit the following page:
http://www.intel.com/support/graphics/sb/cs-009476.htm http://www.intel.com/support/graphics/sb/cs-009476.htm
First of all,thanks for your reply at almost i give up this question.
This is the information.
Intel(R) HD Graphics
Report Date: 4/4/2012 Report Time[hr:mm:ss]: 17:52:3 Driver Version: 8.15.10.2622 Operating System: Windows 7 Service Pack 1(6.1.7601) Default Language: Chinese (People's Republic of China) DirectX* Version: 10.1 Physical Memory: 3797 MB Minimum Graphics Memory: 256 MB Maximum Graphics Memory: 1760 MB Graphics Memory in Use: 904 MB Processor: Intel64 Family 6 Model 42 Stepping 7 Processor Speed: 2394 MHz Vendor ID: 8086 Device ID: 0102 Device Revision: 09
* Processor Graphics Information *
Processor Graphics in Use: Intel(R) HD Graphics Video BIOS: 2130.0 Current Graphics Mode: 1920 by 1080
* Devices Connected to the Graphics Accelerator *
Active Digital Displays: 1 * Digital Display *
Monitor Name: 通用即插即用监视器 Display Type: Digital Gamma Value: 2.2 DDC2 Protocol: Supported
Maximum Image Size: Horizontal: 11.81 inches Vertical: 09.06 inches
Monitor Supported Modes: 640 by 480 (75 Hz) 640 by 480 (60 Hz) 640 by 480 (72 Hz) 720 by 400 (70 Hz) 800 by 600 (72 Hz) 800 by 600 (75 Hz) 800 by 600 (56 Hz) 800 by 600 (60 Hz) 1024 by 768 (75 Hz) 1024 by 768 (70 Hz) 1024 by 768 (60 Hz) 1280 by 720 (60 Hz) 1280 by 800 (60 Hz) 1280 by 800 (75 Hz) 1280 by 1024 (60 Hz) 1280 by 1024 (75 Hz) 1280 by 1024 (70 Hz) 1440 by 900 (60 Hz) 1680 by 1050 (60 Hz) 1920 by 1080 (60 Hz)
Display Power Management Support:
Standby Mode: Supported
Suspend Mode: Supported
Active Off Mode: Supported
Raw EDID: 00 FF FF FF FF FF FF 00 23 2E 60 21 01 00 00 00  03 14 01 03 80 1E 17 78 EA B1 A5 A1 58 4F 95 26  16 50 54 AF CF 00 81 80 81 8A B3 00 95 00 81 00  81 0F 81 C0 01 01 BC 34 00 98 51 00 2A 40 10 90  13 00 68 0E 11 00 00 1E FC 3A 80 00 71 38 46 40  30 20 36 00 D9 0A 11 00 00 1A 00 00 00 FD 00 3C  4B 1E 53 11 00 0A 20 20 20 20 20 20 00 00 00 FC  00 0A 20 20 20 20 20 20 20 20 20 20 20 20 00 5E
* Other names and brands are the property of their respective owners. *
potplayer 32bit (64bit also the same)
http://www.videohelp.com/download/PotPlayer1.5.32007.EXE http://www.videohelp.com/download/PotPlayer1.5.32007.EXE
1,
2,press F5,and you can change output color space there.Be attention,if you change the color space,please close the video and reopen it to take effect
3,press tab key,you can show osd information while playing the video.
4,I have sent an email including the attachment of video sample to your mailbox,please check it.
DArce
I have not received any sample file to replicate this.
Could you please provide a ftp site where we could download this?
DArce
I have followed your indications and I have not been able to see a difference between the two outputs.
I have included a screenshot of the tests done.
NV12
yv12
The system report
Can you use the G530 to finish the test?
