Hello Seanie000, this behavior was reported a few months ago; please check this URL for additional information. http://www.intel.com/support/graphics/sb/cs-009483.htm Graphics Drivers — Errors Reported By Microsoft* Please follow the solutions given on that page.
If you have an OEM system, I would recommend installing the graphics driver they provided, since our drivers are generic and sometimes the OEM system does not allow the installation of them.
You can also try doing a system restore on your computer to the last working state.
Hi Sarah, as i said in my first post i have tried updating the driver and still nothing, is there no other option then to do a system restore? What is the cause of this problem?
Sean, you can try to install our drivers, but it will be necessary to force the installation by performing manual procedure; however I cannot assure you they are going to work as expected.
See here for instructions: http://www.intel.com/support/graphics/sb/CS-022355.htm Graphics Drivers — Computer Manufacturer Graphics Driver Detected
The following link will show you the latest driver available for your system https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22166 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=22166
Please let me know if this resolves your issue.
