22722 Discussions
intel graphics display driver problem after windows 10 upgrade
NHass4
Hi..
I am using Dell inspiron N4050 laptop. Recently i have upgraded my OS from Windows 7 to Windows 10. After the upgrade i was unable to get screen resolution for 1399x768.
the driver display installed shows Microsoft Basic Display Adapter. i tried to install Intel(R) HD Graphics 3000 which was the display before the upgrade. but after install still device manager shows Microsoft Basic Display Adapter. I run the windows update and through windows update, the driver shows successfully installed but still device manager shows Microsoft Basic Display Adapter installed. I cant get the resolution for 1366x768.
please someone help me..
below is the system details and driver details from Dxdiag.
Time of this report: 8/2/2015, 20:54:37
Machine name: SOFTWARE-UPDATE
Operating System: Windows 10 Pro 32-bit (10.0, Build 10240) (10240.th1_st1.150717-1719)
Language: English (Regional Setting: English)
System Manufacturer: Dell Inc.
System Model: Inspiron N4050
BIOS: BIOS Date: 03/23/12 14:05:23 Ver: 04.06.04
Processor: Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz (4 CPUs), ~2.5GHz
Memory: 4096MB RAM
Available OS Memory: 3494MB RAM
Page File: 2732MB used, 4344MB available
Windows Dir: C:\WINDOWS
DirectX Version: 11.2
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 120 DPI (125 percent)
DWM DPI Scaling: UnKnown
Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
DxDiag Version: 10.00.10240.16384 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Microsoft Basic Display Adapter
Manufacturer: Intel Corporation
Chip type:
DAC type:
Device Type: Display-Only Device
Device Key: Enum\PCI\VEN_8086&DEV_0126&SUBSYS_05021028&REV_09
Display Memory: 1746 MB
Dedicated Memory: 0 MB
Shared Memory: 1746 MB
Current Mode: 1024 x 768 (32 bit) (64Hz)
Monitor Name: Generic Non-PnP Monitor
Monitor Model: unknown
Monitor Id:
Native Mode: unknown
Output Type: Internal
Driver Name:
Driver File Version: ()
Driver Version:
DDI Version: 11.2
Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Driver Attributes: Final Retail
Driver Date/Size: , 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a.
please someone help....
Anonymous
Not applicable
It is necessary to use the generic driver of Microsoft® Windows 10.
Intel® HD Graphics 3000 is not compatible with Microsoft® Windows 10.
http://www.intel.com/support/graphics/sb/CS-034343.htm?wapkw=cs-034343 http://www.intel.com/support/graphics/sb/CS-034343.htm?wapkw=cs-034343
Mike C
NHass4
which drivers i can use..can u give a download link..my laptop looks disgusting now..:(
Anonymous
Not applicable
It is necessary to use the generic driver of Microsoft® Windows 10. Using Microsoft® Windows update utility.
Mike C
VGuan
Hi I have the same unit as you do with the same problems. Did you already upgraded to win10?
Anonymous
Not applicable
The 2nd Generation Intel® Core™ Processors with Intel® HD Graphics 3000/2000 are unfortunately not compatible with Microsoft® Windows 10. If Intel improves the compatibility in the future, it will be posted on the link below:
Supported Operating Systems
http://www.intel.com/support/graphics/sb/CS-034343.htm?wapkw=cs-034343 Graphics Drivers — Supported Operating Systems
Mike C
