22959 Discussions
intel hd 4000 with i5-3570k windows 10
mpede5
Hello i got a pretty annoying issue, i been struggeling with for about 2 months now and i submit defeat and ask for help.
I upgraded a acer x1935 with 16gb ram and i put in a i5-3570k, installed windows 10 pro 64 bit, drivers didnt work, updated windows to 1703 still drivers didnt work, reinstalled windows about 3 times with different drivers other forums suggested no luck, for giggles i even tried to install windows xp 64 drivers and still got same result, when i booted up my pc it went to windows start screen and poof, computer crashed with screen looked a little like the one i uploaded.
i tried just about every driver on Intels homepage, tried the diagnose tool and the tool for auto update drivers and all was to avail..
so question what do i do wrong?
windows 10 pro 64 bit, version 1703
16gb ddr3 ram
500gb hdd
i5-3570k
intel b75 chipset motherboard
HDMI to HDMI
hope you guys can help 🙂
Stefan3D
Use this driver
If you encounter an error message about compatibility or validation, proceed like this:
Create a system restore point
https://support.microsoft.com/en-us/instantanswers/e6bbddb0-9db4-4d88-9063-42c52c79a96e/create-a-system-restore-point
Install the desired driver via "have disk method" as described at:
http://www.windowscentral.com/how-install-intel-beta-graphics-drivers-surface
(ignore prolog about MS surface)
mpede5
Hello Stefan3d i tried that patch and tried it with a fresh installment of windows 10, and still got that screen flicker crash with no error messages. and even tried the "have a disk method" and still no help, only time i had it running was when i just put the cpu in and used "Microsoft basic display driver" lagged in games but could run, but when i installed any drivers with intel or windows update with intel in it, it "flicker crashed" on install or shortly after.
Thank you to Stefan3D for the suggestions provided previously.
michael84: Thank you very much for joining the Intel® graphics communities.
Remember that the Intel graphics drivers are generic, meaning they might or might not work with your system. That is why we always recommend to install the drivers provided by the manufacturer of the laptop, since they were customized in this case by Acer to work with that specific system.
I looked in their web site actually Windows® 10 is not supported, the PC supports Windows® 7 or 8. Based on that you will find the proper graphics driver for this computer on the following link, please look for VGA:
https://www.acer.com/ac/en/US/content/support-product/4081?b=1 https://www.acer.com/ac/en/US/content/support-product/4081?b=1
Any further questions, please let me know.
Alberto R
