My setup is:
-Gigabyte Brix pro i7 4770R
-Windows 7 64-bit
-Dell up2414q monitor connected with a DisplayPort cable
I would like to have the full resolution of 3840x2160 @ 60Hz. The display is 10-bit capable as well, I would like this to work but will settle for 8-bit.
With Intel HD graphic driver 10.18.10.3282 installed from the Gigabyte website:
-The monitor appears as two monitors
-Both tiles appear as 1920x2160 @ 60Hz
-I can run it in extended mode
-I tried using the Intel collage mode, but the first time it cause the BSOD, and the other times the driver just crashes when you hit apply
-If it Intel collage mode had worked I think this would have everything working like I want
With the newest Intel HD graphic drivers 15.36.7.64.3960 or the previous 15.36.3.64.3907
-The monitor appears as one 3840x2160 panel
-In the Intel control panel I can set it to 3840x2160 at 60Hz
-The monitor indicates it is receiving a 60Hz signal
-Moving the mouse around looks like 30Hz, much much less smooth than when running in extended mode under 10.18.10.3282
-Running Dxdiag.exe, and looking under display shows a resolution of 3840x2160 at 30Hz 😞
So to summarise, running the previous driver proves that the iris pro 5200 can drive the monitor at the full 3840x2160 @ 60Hz. I just can't get it to show it as one big screen, only two seperate monitors. And the newest drivers seem to have some weird issues.
Any help appreciated. It's a bit frustrating having such a monitor and not being able to use it as it was intended due to some software bug.
Deeksie
Installed the newest driver for about the 3rd time...and wonderfully it now seems to work. I have know idea why it didn't the last 2 times, but I'm very glad it is now! 🙂
Hi Deeksie,
Thanks for joining the Graphics community.
Please attach graphics report generated within graphics control panel.
http://www.intel.com/support/graphics/sb/cs-009476.htm Graphics Drivers — Intel® Graphics Driver Report
Make sure you have loaded the latest video drivers:
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=3723 Intel® Download Center
Allan.
