23095 Discussions
iris xe dual-monitor setup
Unskilleddra9on
I might just be an idiot but I googled to see if the iris xe chip can run 2 monitors and it said it can do up to three, i am using one monitor on an actual hdmi port and attempting to get another one to run on a usb-c to hdmi adapter. They all work separately but when used in conjunction become useless, i can't even detect it through display settings. I've made sure i have the newest display driver installed and my computer is completely up to date so idk if i'm stupid or just doing something wrong.
Monitor one: samsung 27" CHG70 gaming monitor with quantum dot
Monitor two: ASUS TUF 28" VG289Q1A
Laptop:  HP Laptop 15-dy2xxx
idk if these are relevant to my problem but might as well include them.
Steven_Intel
Hello Unskilleddra9on,
I am sorry you are having issues with your Intel® Iris® Xe Graphics, I will be glad to help.
By any chance, were you able to get both monitors to work together in the past? If so, was there any change that may have triggered the issue?
As well, please download the Intel® SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
Open the application and select "Everything", click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". To save your scan, click on "Next", then "Save". Please attach the file to your reply.
Steven G.
Steven_Intel
We would like to know if you were you able to check the previous post.
Steven G.
Steven_Intel
Since we have not heard back from you, we will close this thread. If you need any additional information, please submit a new question, as this thread will no longer be monitored.
Steven G.
mohsinmem
Hi I'd like to pick up on this conversation. I came to this post as I researched why my laptop was performing so poorly after connecting to two other screens. My task manager tells me my CPU usage is 34% and  Memory 55% (below). Turns out it's the refresh rate across multiple screens is the issue. I'm wondering if there's something you can suggest that will reduce the significant lag I'm experiencing (image below). My understanding of this issue currently is that this is a graphics card processing issue. But I'll let you figure and let me know. I followed the instructions you asked the original user to take and here's my system scan: https://drive.google.com/file/d/1qDFQxzDjCHF9WM1kdZ6DK0WKBwieS662/view?usp=drive_link
Thank you for your assistance 🙏
