hello, i have a laptop with i5 10200h processor. When I go to the intel website, I see that this version is old, but the intel driver support assistant shows that it is up-to-date and the version is very old, my computer technical service said it is up-to-date, but it is not the same as the version on their site, how can I follow? my version is 27.20.100.9365
With a laptop, you should always use the driver provided by the laptop manufacturer.
Using the Intel generic driver may cause you problems.
[Waiting for Windows 12]
so my driver version old but i cant update it am i understund right? its not latest version i guess
No, you can update it. It is just that you "may" have issues.
You can find the latest driver here:
https://www.intel.com/content/www/us/en/download/19344/intel-graphics-windows-dch-drivers.html
Now, Microsoft may reinstall an older driver, thinking they know what is best for you. If this occurs, you can "hide" the Microsoft driver.
thanks for answers, i try to update this link but i see exit code 8 and i cant update my laptop manifacturer say its latest version but it isnt if i see wrong
27.20.100.9365 this is my version
30.0.101.1340 is the latest version, released just 10 days ago.
i try to update but i see exit code 8 and i dont know what i do because manifacturer says its latest version they cant help me
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
Hello bugraozet
Thank you for posting on the Intel️® communities. To get the SSU file please:
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Share the .txt file with us
David G
David G.
David G.
