22989 Discussions
my hdmi is no longer working
mprin1
i use a hdmi to my 42 ich tv but it stoped working vga still working.. tryed a few diffent hdmi cables and still nothin.it was working fine until yesterday my power went out and 1 hour later came back on. computer does not even notic the hdmi plug into the computer nor does the tv.. yea its on a powerstrip..
heres what i got
windows 7 64bit
intel i7 4790k should be the 4600 graphics
msi z97 gaming 5
m.2 ssd 256
32gb ddr3 1600
850 power supply.
what i have tried..
reinstalling drivers. resetting memory. memory check
Allan_J_Intel1
It seems to be a problem caused when the power went out. Do you get video with different video cables?
If you are getting video with DVI, Display port cables, I recommend testing with the driver linked below:
Allan.
mprin1
i tryed that driver and it did not work i know its not the cable i plugged it to my DVR tho bright house and works fine.. even using the hdmi cable the DVR was using same problem and i am useing the vga on the motherboard.. heres my dxdiag
Allan_J_Intel1
If you have tried the "test driver" and still experiencing HDMI issues, the problem might be hardware. The HDMI port on your computer.
I would recommend checking with your computer manufacturer for other troubleshooting options. Also, if possible try to reinstall the operating system and then the latest video drivers to see if this would be registry problem or hardware.
Allan.
