22869 Discussions
new A770 DP not working
JW19
I am working on a new build using the MSI B760m motherboard.  When I boot the computer only the HDMI port works on the A770 graphics card.  I cannot get any of the DP to work.  I want to use multiple monitors.  I have tested with several different monitors,  adapters, and cables with no luck.
I cannot get the DP to work even to get into the bios.
The motherboard HDMI and DP work fine.
Earl_Intel
Hi JW19,
I'm sorry to learn that you are experiencing issues with your Arc A770. Rest assured that we will find the best solution for your concern.
For us to further investigate on this, kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
Earl_Intel
Hi JW19,
Just wondering if you had a chance to look over the questions I posted. In order to decide on the appropriate course of action to address this issue, kindly inform me as soon as possible.
Earl E.
Earl_Intel
Hi JW19,
Earl E.
