23106 Discussions
placa madre inter desktop board DH61WW
dsala4
buenas tengo una placa madre inter desktop board DH61WW le coloque memoria nueva kingston 2gb ddr3 1333 mhz y me suena un pito y no me da video investigue la placa madre y me dice que soporta ese tipo de memoria si me pueden ayudar? por favor gracias
Hello davidsystem,
Thank you for contacting the Intel community.
I'm sorry that it took me some time to come around to this post and to be able to help you.
At this point, I have check the memory specifications you provided and it should be fine; however, Intel has not tested this with this motherboard, the memories tested by Intel can be checked here:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005810.html http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005810.html
You could try one ram at a time on the DIMM closest to the processor and see what the result is.
Now, you said that you get a beep when you start the system, is it only one beep or more than one?
Ivan.
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
