- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
Good morning,
I think I have a graphics driver issue:
- some time ago I opened google maps and the names of the street, cities, etc ... came out well, but after 3 seconds it disappears.
- I open an hp brand printer application, and fill out the form, the second window is blank.
- I open a website, for example, and the format is unconfigured.
I use the web, edge, I also tried Chrome and it's still the same.
My details are: S.O .: Windows 10 Home Edition, Version 20H2,
Installed on 22/10/2020
Operating system version 19042.685 Windows Feature Experience Pack 120.2212.551.0
System type: 64-bit operating system, x64-based processor
Connection to connect the monitor to my computer: DVI-D Single Link
Equipment: PC, single monitor
Graphic Drive: Updated Intel (R) Core (TM) i7-8700 CPU processor @ 3.20GHz 3.19 GHz
I tried another monitor and the problem continues I attach the images Can you help, please!
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Berenguer,
Thank you for posting on the Intel* Community.
To better assist you, please provide us with the below information:
- Does the issue start after a graphics driver update/Windows Update?
- By any chance, did you change or review the performance settings in Windows* (related to visual graphics effects, backgrounds, animations, etc)?
Provide the Intel® System Support Utility (Intel® SSU)
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
Maria R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Good morning,
Following in your footsteps, I attach you.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Berenguer,
After checking the information, we cannot address this issue to the driver since it is the first report we have about the behavior and we tested a system with UHD Graphics 630 and we do not see the behavior.
Keep in mind that you are using a generic driver from Intel*, the best thing to do is to use the drivers provided by the system manufacturer (motherboard manufacturer) or through Windows Update to eliminate the potential impact caused by loading non-custom drivers.
We think that your issue is more related to the Operating System, this may be related to the Windows* performance settings (related to visual graphics effects, backgrounds, animations, etc), we encourage you to contact Microsoft so they can properly guide you to verify this behavior.
Maria R.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Hello Berenguer,
Maria R.
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
