Hello beko,
Size yalnızca İngilizce olarak yardımcı olabileceğimi lütfen unutmayın. Bu yanıtı çevirmek için bir web çeviri aracı kullandım, bu nedenle bazı yanlış çeviriler olabilir. İleriye dönük olarak, size İngilizce olarak cevap vereceğim.
The driver notification is from a 3rd party application. To better help understand the issue, please help share the following information below:
1) Are you having any system or application issues that prompts you for a driver update apart from the driver notification from CC Cleaner?
2) Please share your system configuration so I can check the best drivers that you may install, if needed. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
- Scan: Check the box Everything.
- Click Scan.
- Review: When finished scanning, click Next.
- Click Save (.txt). Attach the file as you reply.
I will wait for your reply.
JeanetteC.
Hello beko,
I'm following up to check whether you have had the chance to review my previous post. Let me know if you need time to share the details I asked for. This will help identify the next steps that need to be taken to resolve this issue.
JeanetteC.
Hello beko,
I have not received any response in the past few days. I will now proceed in closing this thread.
Sincerely,
JeanetteC.
