22827 Discussions
u7 265k编码器在obs过载(也许是异常
wzx
u7 265k在obs内录制2560*1080 60p qsAV1 tu7(fastest)时265k的编码器严重过载,独立显卡为b580,obs运行在集成显卡上
win11版本         24h2
显卡驱动版本    .7028
obs版本             31.1.2
主板                    msi Z890 Carbon
显卡                    b580+265k Graphics
DeancR_Intel
Hi wzx,
请注意,我只能用英语为您提供支持。我已经使用网络翻译工具来翻译此回复,因此可能存在一些不准确的翻译。
Thank you for contacting Intel support regarding the encoder overload issue you're experiencing with your Intel Core Ultra 7 265K processor when recording in OBS.
I understand that you're encountering severe encoder overload with the 265K's encoder when recording at 2560x1080 60fps using QSV AV1 TU7 (fastest preset), while OBS is running on the integrated graphics and you have a B580 discrete graphics card.
System Information Noted:
  • Processor: Intel Core Ultra 7 265K
  • Graphics: B580 + 265K Graphics (integrated)
  • Motherboard: MSI Z890 Carbon
  • OS: Windows 11 24H2
  • Graphics Driver: 32.0.101.7028
  • OBS Version: 31.1.2
  • Recording Settings: 2560x1080 60fps, QSV AV1 TU7 (fastest)
  • Issue: Severe encoder overload on 265K encoder
This appears to be a performance issue with the integrated graphics encoder when handling AV1 encoding at your specified resolution and frame rate. The encoder overload suggests that the integrated graphics may be reaching its processing limits with these settings.
Given the technical nature of this encoding performance issue, I'd like to schedule a phone call for faster resolution.
Dean R.
DeancR_Intel
Hi wzx,
Dean R.
wzx
很抱歉,受限于时间未能及时回复,接下来我会尝试尝通过更换为核显输出画面来测试一些其他工作场景,最终结果我也会在此回复,应该是下周一,因为我正为了一些其他事情忙碌。如果结果并未改善,当你想进行一场电话回访时,也许下周二是个好机会。
DeancR_Intel
Hi wzx,
Thank you for your response and for taking the time to update me on your situation. I completely understand that you've been busy with other matters - no need to apologize for the delayed response.
It's a great approach to test different work scenarios by switching to integrated graphics output. This will help us better understand if the encoder overload issue is related to the specific configuration or if it's a broader performance concern with AV1 encoding on the 265K.
I look forward to hearing your test results next Monday. If the issue persists after your testing, Tuesday would indeed be a good opportunity for a phone call to provide more direct assistance.
I'll send you a private email with additional details for scheduling the call.
Dean R.
wzx
由于一些突发性的事件,我的测试由只能今天开始,但当我将驱动更新为7029时,这个问题似乎消失了,我的265k的编码器已经可以正常工作了,包括b580的编码器,7028时虽然工作正常,但在win任务管理器中观察几乎满载,如今占用已经大幅下降。我附带了当前驱动版本我已经测试过的情况的汇总图表,以及我的系统版本,驱动版本以及我的录制格式。由于一些突发性的情况,我原本计划与先前版本的对比并不能进行,我的windows版本以及显卡驱动版本都以及更新(当然windows是自动更新),我无法确定问题究竟是如何解决,因为变化不止一个,但是现在,它解决了。当然,如果你想继续了解一些详情,我稍后会回复你的私人电子邮件
PixPin_2025-09-15_09-34-41.pngPixPin_2025-09-15_09-35-07.pngPixPin_2025-09-15_11-21-38.png
wzx
问题再次出现了,由于上次更新时我的主板bios意外恢复默认,我的内存频率回归5600MT/s,且我上述的实验也运行在该频率下,当我刚刚注意到这个问题的时候,我将我的内存频率修改回8400MT/s,编码器过载的现象再次出现了。就目前的情况判断,这似乎是内存频率的问题,但我不确定这个问题是否仅仅出现在OBS中,在pr又或者是DaVinci Resolve上貌似并未出现,偶不,真正的原因是我的pr或DaVinci Resolve并没有运行在265k xe核显上,看来我需要重新测试一下了
