22974 Discussions
update: hd4600 with vg248qe no support for 144hz video refresh rate
DH10
Hi there,
I'm using a 4690K. I do have a dedicated graphics card but i disabled it in the bios. I'm Using z97 board with 64bit windows and has been done no overclocking.
pretext:
Using my dedicated graphics (sapphire 7870 OC) card 144hz (video refresh rate) at 1080p is working but i do get occasional black screens on my monitor (VG248QE). To check out wether it is my card or the new monitor i was planning on using the intel graphics card to check.
problem:
Disabling the dedicated graphics card an installing the intel drivers did work fine. First i did used the Win64_153322 version. I had an option the manually set the resolution. But i had to restart so i didn't change anything. After the restart i do not find this option anywhere.
The only resultions i can choose from are with 60hz (59hz). (My Monitor VG248QE support 144hz)
I did uncheck the windows setting to only show matching video refresh rate but to no avail (only got 24 - 60hz selections there).
I tried uninstalling and reinstalling the drivers.
I installed the beta driver win64_1536b. No change. I reinstalled the Win64_153322 version.
All attemps above where with dual dvi connection.
I tried to connect via hdmi which gave me a few more options (but no usefull ones - more like 60i hz / 60p hz (interlaced and progessive))
The log below is made via dvi connection even so it states hdmi!
Do you have any idea how (and if possible at all) i can get the hd4600 to use a higher video refresh rate?
thanks a lot in advanced,
Daniel
update:
I did find the CustomModeApp.exe (in the driver folder) where you can change an add resolution and refresh rate by hand. Sadly i get told that the bandwith is to small. Even by reducing the resolution I'm not able to run a higher refresh rate.
If anything is unclear i will try to explain it differently as english is not my mother tongue - sry.
Using CustomModeApp.exe without success.
Jose_H_Intel1
Hi Daniel, the document below lists 60Hz as the maximum refresh rate supported.
https://software.intel.com/en-us/articles/quick-reference-guide-to-intel-processor-graphics Quick Reference Guide to 4th Generation Intel® Core™ Processor Graphics (formerly codenamed Haswell) | Intel® Developer …
ROBERT_U_Intel
@ dh2, Following is the information on 144Hz support that should help you configure your system.
When using DVI:
Intel HD Graphics 4600 Does not support Dual DVI natively (however DP to Dual DVI Active Dongle might work- but not supported ) and Max Pixel Clock is supported on Single Channel DVI is 165Mhz.
So max on DVI at 1920 x 1080 is 60p Hz.
HDMI :
Intel HD Graphics 4600 Max Pixel Clock supported on HDMI is 300Mhz. So max on HDMI at 1920 x 1080 is 60p, 85p,100p, 120pHz.
Note : 1920 x 1080 (144p Hz) is not supported on HDMI as it Exceeds the max Pixel Clock supported by our Intel HW ( 300Mhz)
Driver will enable and support 300Mhz based on HDMI Panel's (HDMI Registration ID supplied by panel )
When using DispalyPort :
Intel HD Graphics 4600 Max Pixel Clock supported on DisplayPort Various based on SKU - ( Based on CD Clock of the SKU – Which is OEM setting via System bios.)
So based on what the BIOS has enabled, at 1920 x 1080, 60p, 85p,100p, 120p,144pHz are supported.
We tested based on your configuration and found the following:
With DisplayPort, working fine on DisplayPort Interface ,Which means we are able to see and apply 1920 x1080 @ 144Hz without any issue..
Above is from our CUI. Driver used : 10.18.10.3618 ( Dated 5/12/2014 )
Robert
DH10
Thanks a lot for your very helpful and extended answer! I will try to use the displayport-connection but as I do not have the necessary cable at hand it will have to wait till it is delivered.
Again thanks a lot, this is much more support than expected.
Daniel
SAlri
I have the exact same issue but I dont understand how you got it to work. Im using an ASUS VG278HE that is 144hz and my MSI laptop has an Intel HD 4600 as its integrated and a 860GTXM as well.
SAlri
I have the ASUS VG27HE and it doesnt have display ports unfortunatley, just HDMI, DVI, and VGA.
My laptop has one HDMI and 2 Display port adapters. Its using Intel HD 4600, aswell as a GTX860M.
How do I get this monitor to run at 120HZ? I dont really need the full 144.
Would i be able to get 144hz or atleast over 60hz by using a DisplayPort converter from my laptop to a DVI or HDMI cable? i cant get over 60hz even by only using a HDMI cable
Henry_A_Intel1
Hello toresson91;
I am affraid the converters from Display Port to DVI or HDMI will also lower the display setting. Which means you will not be able to get the full 144hz.
Regards;
Henry A.
I am using Acer 24" Predator GN246HLBbid 144Hz Gaming, and it does not have DisplayPort either, but cant get it to run at 120hz. any answert for that?
