Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
which resolution i need to work with?
Hi
I have a dell laptop with 1920/1080p resolution.
I have 4K tv and when i connect the dell to it the resolution change to the tv resolution which is 3000 something on 2000 something (sorry don't remember but 4K resolution)
i work on one screen, not duplicated.
Do i need to leave it that way or should i change it to 1920/1080p?
The main use is for movies and tv-shows and they are mostly in 1080p resolution.
thank you...
Tags (1)
Community Manager
Hello odedc
Thank you for joining the community.
Could you provide us with your system information? What is the laptop model and TV model?
Are you having any errors with this display configuration? In my opinion, if you are not having error y don't see the need to change the resolution.
Leonardo C.
Highlighted
Community Manager
it's a DELL inspiron 5570
and the tv is 55' samsung mu9000
i'm not having trouble
just want to view as good as i can..
thanks
Highlighted
Community Manager
Hello odedc
Thank you for your response.
With the tv plugged in on the system could you run the Report for Intel® Graphics Drivers?
https://www.intel.sg/content/www/xa/en/support/articles/000005848/graphics-drivers.html https://www.intel.sg/content/www/xa/en/support/articles/000005848/graphics-drivers.html
Please attach re result to the tread.
Leonardo C.
Highlighted
Community Manager
Hello odedc
I was checking your case and would like to know if you need further help. If so, please do not hesitate in replying back.
Leonardo C.
Highlighted
Community Manager
thank you so much for asking,
I found out that i should stay with the tv resoulution.
once again, thank you.
