23258 Discussions
windows 10 intel hd 4600 memory leak
DKlec1
I have desktop with i7, graphics intel hd 4600, 8GB ram. A few days ago i've installed windows 10.
When i use microsoft driver for my graphics card system uses 1,2GB ram.
But... when i install driver Intel® Graphics Driver for Windows® 10 [15.40][4th Gen] OR Intel® Beta Graphics Driver for Windows® 7/8.1/10* [15.40] system uses 5,6GB.
System works stable but i cannot run virtual machines or other things that needs more memory.
I'm sure that it's problem with this because i following system monitor when i uninstall drivers for graphics card.
What can i do to repair that problem?
DKlec1
Hi
I cant't find out what is wrong so I decided to wait. And... Today everything works. I was installed driver from January but the problem sometimes shows up. And after some windows updates now everything works. I have opened chrome... and I have used 2,9/8GB.
Thanks for your help.
Allan_J_Intel1
Please fill out this form and I will try to replicate this issue:
Allan.
DKlec1
Category
Questions
Answers (N/A if not applicable)
Description
Provide a detailed description of the issue
When I install intel driver for hd 4600 my ram usage increased from 1.2GB to 5.9GB.
Does it fail every single time, or only sometimes?
If you can offer a % rate please do.
100%
Hardware (HW)
Brand and Model of the system.
windows 10 pro 64 bit
Hybrid or switchable graphics system?
ie Does it have AMD or NV graphics too?
only intel graphics. it's desktop.
Make and model of any Displays that are used to see the issue (see note2 below).
LFP = Local Flat Panel (Laptop panel)
EFP = External Flat Panel (Monitor you plug in)
EFP
How much memory [RAM] in the system (see note2 below).
<td style="padding: 0 5.4pt; border-right-width: 1pt; border-bottom-width: 1pt; border-style: none solid so...
Allan_J_Intel1
I have installed the latest beta driver version 4326 but I am not getting same issue as you described.
Please post pictures where your computer shows memory usage.
Allan.
Bryce__Intel
kledan
Could you please post pictures showing memory usage?
1. With latest driver, take a pic
2. Roll back to previous driver, take a pic
3. Uninstall graphics driver, take a pic
Bryce__Intel
Hi kledan
Development is pinging me on this one needing more info still from you. Could you help provide so we can investigate further? Appreciate it!
DKlec1
Hi
Allan_J_Intel1
Great to hear the computer is working again.
Allan.
