Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Erreur SSD 545s 10/106
Bonjour,
Depuis quelques jours maintenant en utilisant SSD optimizer j'ai une "erreur 10/106"
SSD toolbox est à jour, le firmware aussi.
Comment régler le problème, merci.
For a few days now using SSD optimizer I have a "10/106 error"
SSD toolbox is up to date, the firmware too.
How to fix the problem, thank you.
Highlighted
Re: Erreur SSD 545s 10/106
So we can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (look at the instructions under the reply window).
Doc
Highlighted
Fichier joint, merci beaucoup.
Attachment, thank you very much.
