Intel® ARC™ Graphics
1613 Discussions
显卡A770 启动程序没有使用GPU
xingshun
第一张是我的电脑配置,第二张里有个YGOPro2的程序显示吃满99%的GPU,而实际上并没有使用到GPU,从上面的总GPU消耗23%可以看出,并且程序实际操作也能明显感觉出没有使用到GPU。
这个并不是这个程序的特例,即使只打开chrome,时间一久后打开第二个程序就会像上面一样吃不到GPU,任何程序都会这样子。
有没有办法可以强制程序使用GPU加速吗?
Hugo_Intel
Hello xingshun
Thank you for contacting Intel® ARC™ Graphics Communities. I am sorry to hear that you are experiencing issues when using your Intel® Arc™ A770.
Please let us know the following information to assist you with this issue:
  1. What steps do you follow to reproduce this issue?
  2. Is Resizable BAR enabled on your system?
  3. Is there any error, crashes, or low-performance issue as a result of the behavior you describe? Please attach screenshots or a short video if there are any.
  4. Please run the Intel® System Support Utility and attach the log file.
Hugo O.
Hugo_Intel
Hello xingshun
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello xingshun
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
