Intel® ARC™ Graphics
2851 Discussions
关于游戏黑神话悟空A750显卡XESS优化问题
王代炜
您好: 我想建议一下关于A750显卡运行游戏黑神话悟空时,XESS无法开启帧生成功能,如果选用XESS帧数明显低于流畅游玩水平,会卡顿,达不到60帧,望英特尔公司可以继续优化驱动,可以支持黑神话悟空开启XESS后可以用帧生成,望回复。
DeancR_Intel
Hi 王代炜,
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。
Thank you for posting in Intel Community!
Please make sure you provide the following basic information when reporting a bug:
  1. What is the graphics driver you are using?
  • Confirm you are using the latest WHQL graphics driver available (let us know the exact driver version you are using).
  • A clean driver installation using DDU in safe mode is recommended. Follow this link for instructions.
  • You could also test using the latest Beta driver. Our Beta drivers go through all Intel quality assurance processes and are safe to use for evaluation.
  1. Tell us the name of the game or application and where to obtain it (Steam, Epic, etc.)
  2. Provide us with the Intel SSU report from your system.
  • If you do not wish to submit the SSU report then at least provide us with the following information about your system:
    • Processor make and model.
      • Power Supply make and model.
    • Motherboard make and model.
    • Amount of memory (RAM).
    • Operating System version/build number.
  1. Tell us the steps to reproduce the issue (this is very important!).
  2. For graphics corruption (per example artifacts, textures corruption or lighting glitches) please use Intel Arc Control to capture screenshots or a video showing the bug.
Dean R.
DeancR_Intel
Hi 王代炜,
Dean R.
DeancR_Intel
Hi 王代炜,
Since I haven't received a response from you, I will be closing this inquiry. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dean R.
