Intel® ARC™ Graphics
3050 Discussions
그래픽 장치 문제에 대하여
comics14
Arc(TM) A370M Graphics 와  lris xe 를 사용중인데, L.O.L을 돌릴때마다 '그래픽 장치를 초기화 할수 없다' 고 경고가 뜨고 게임이 종료 되는데 왜이럴까요?
VaishnaviV_Intel
Thank you for posting your question. We only provide support in English. I have translated your question. "I'm using Arc(TM) A370M Graphics and LRIS XE, but every time I run L.O.L, the game closes with a warning that 'Unable to initialize graphics device', why is this so?"
Does this reflect your question correctly?
Thanks & Regards,
Vankudothu Vaishnavi.
Hugo_Intel
Hello comics14
영어로만 지원할 수 있음을 알려드립니다. 이 응답을 번역하기 위해 웹 번역 도구를 사용했기 때문에 일부 부정확한 번역이 있을 수 있습니다.
Thank you for posting on the  Intel® ARC™ Graphics. I am sorry to hear that you are experiencing issues when trying to play League of Legends on your Intel® Arc™ A370M Graphics.
As a first approach to this issue, please completely uninstall the game from your system and reinstall it. If the issue persists, please share with us the following information:
Hugo O.
Hugo_Intel
Hello comics14
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello comics14
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Hugo_Intel
Hello comics14
Before we close this thread we wanted to ask you besides the information requested in my first post for the following:
Create a log file using the instruction in the following article and attach it to your reply:
How to Extract Information from the DirectX* Diagnostic Tool
From the same tool, share with us screenshots from the System and Display tab
The information will be highly appreciated in order to investigate this issue.
Hugo O.
