Intel® ARC™ Graphics
2262 Discussions
A750 Vram overheating
LotusXhir
I buy Arc a750 Limited Edition 2 days ago, I saw that the of my graphics card Vram was 90 degrees and sometimes it was 92-94 degrees. Is this normal?
Driver version : 31.0.101.4972
Bios is up to date
I did not overclock the graphics card, it is completely stock.
ReSize BAR open
Andres_Intel
Hello LotusXhir,
Thank you for posting on the Intel communities. I understand that you are concerned about the VRAM temperatures. I see your temperature is running between 92-94 degrees. Based on this, we would like to let you know that the Intel Arc card threshold is 90°C. Every temperature lower than that is considered expected and should not affect the graphics card's lifespan.
In this case, to look deeper into this situation, please answer the following questions:
Andres P.
Andres_Intel
Hello LotusXhir,
Were you able to get the information requested in the previous questions?
Andres P.
Andres_Intel
Hello LotusXhir,
Andres P.
Azijur
same isuu when i try to play red dead redemption 2 my gpu temperature also same it goes up tp 90 degrees
