Good evening everyone. I just got my a750 yesterday, beautiful card..... Anyway, I did a fresh install of windows 11 on a brand new ssd. The motherboard, CPU, and RAM were already in use in the system the ARC is replacing an old gtx 750ti. Anyway, 2 minutes into loading the game No Man's Sky, the whole system crashes with the video_scheduler_internal_error. This happens with both the Beta driver and standard driver. Is there a possible fix for this or do I need to wait till a driver update resolves the issue? Thank you for the help!
I´m Facing the same issue on my A750 as well. even tried deleting the game´s graphic setting file before starting it. ReBar is enabled on my sytem and other games work fine
Hello @Parz1val
Thank you for posting on the Intel® communities. I'm sorry for the inconvenience this might have caused you.
In order to assist you can you please help us with the following information:
- Download and install the Intel
System Support Utility (Intel SSU): https://www.intel.com/content/www/us/en/download/18377/25293/intel-system-support-utility-for-windows.html? Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View". Click on the menu where it says "Summary" to change to "Detailed View". Click on "Next", save the report and attach it to your response. - Please run a graphics report following this article https://www.intel.com/content/www/us/en/support/articles/000005848/graphics.html, especially Intel Graphics Command Center (Intel GCC)
Carlos L.
Hello @Parz1val
Carlos L.
Hello @Parz1val
Carlos L.
