Intel® ARC™ Graphics
2903 Discussions
A770 PCIe link negotiates for x1 on a 3.0 x16
karthikeyan
I am facing PCIe link negotiation issue on ubuntu 22.10, 6.2.0-060200rc6-generic kernel
I haven't installed intel drivers yet. previously I was using AMD Vega II and there was no PCIe link issue.
Motherboard: Gigabyte X399 Aorus Extreme
Bios version: F6a
Processor: AMD Ryzen Threadripper 2990wx
~$ glxinfo -B
name of display: :0
display: :0 screen: 0
direct rendering: Yes
Extended renderer info (GLX_MESA_query_renderer):
Vendor: Intel (0x8086)
Device: Mesa Intel(R) Arc(tm) A770 Graphics (DG2) (0x56a0)
Version: 23.1.0
Accelerated: yes
Video memory: 256MB
Unified memory: no
Preferred profile: core (0x1)
Max core profile version: 4.6
Max compat profile version: 4.6
Max GLES1 profile version: 1.1
Max GLES[23] profile version: 3.2
OpenGL vendor string: Intel
OpenGL renderer string: Mesa Intel(R) Arc(tm) A770 Graphics (DG2)
OpenGL core profile version string: 4.6 (Core Profile) Mesa 23.1.0-devel (git-b1a3378 2023-02-03 kinetic-oibaf-ppa)
OpenGL core profile shading language version string: 4.60
OpenGL core profile context flags: (none)
OpenGL core profile profile mask: core profile
OpenGL version string: 4.6 (Compatibility Profile) Mesa 23.1.0-devel (git-b1a3378 2023-02-03 kinetic-oibaf-ppa)
OpenGL shading language version string: 4.60
OpenGL context flags: (none)
OpenGL profile mask: compatibility profile
OpenGL ES profile version string: OpenGL ES 3.2 Mesa 23.1.0-devel (git-b1a3378 2023-02-03 kinetic-oibaf-ppa)
OpenGL ES profile shading language version string: OpenGL ES GLSL ES 3.20
4b:00.0 VGA compatible controller: Intel Corporation DG2 [Arc A770] (rev 08) (prog-if 00 [VGA controller])
Subsystem: Intel Corporation Device 1020
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin ? routed to IRQ 314
NUMA node: 2
IOMMU group: 19
Region 0: Memory at 9c000000 (64-bit, non-prefetchable) [size=16M]
Region 2: Memory at 80000000 (64-bit, prefetchable) [size=256M]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [40] Vendor Specific Information: Len=0c <?>
Capabilities: [70] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 128 bytes, PhantFunc 0, Latency L0s <64ns, L1 <1us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
DevCtl: CorrErr- NonFatalErr- FatalErr- UnsupReq-
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop+ FLReset-
MaxPayload 128 bytes, MaxReadReq 128 bytes
DevSta: CorrErr- NonFatalErr- FatalErr- UnsupReq- AuxPwr- TransPend-
LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk-
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 2.5GT/s, Width x1
TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range B, TimeoutDis+ NROPrPrP- LTR+
10BitTagComp+ 10BitTagReq+ OBFF Not Supported, ExtFmt+ EETLPPrefix-
EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
FRS- TPHComp- ExtTPHComp-
AtomicOpsCap: 32bit- 64bit- 128bitCAS-
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
AtomicOpsCtl: ReqEn-
LnkCap2: Supported Link Speeds: 2.5GT/s, Crosslink- Retimer- 2Retimers- DRS-
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
Retimer- 2Retimers- CrosslinkRes: unsupported
Capabilities: [ac] MSI: Enable+ Count=1/1 Maskable+ 64bit+
Address: 00000000fee00000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [d0] Power Management version 3
Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
Capabilities: [100 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 0
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [420 v1] Physical Resizable BAR
BAR 2: current size: 256MB, supported: 256MB 512MB 1GB 2GB 4GB 8GB 16GB
Capabilities: [400 v1] Latency Tolerance Reporting
Max snoop latency: 0ns
Max no snoop latency: 0ns
Kernel driver in use: i915
Kernel modules: i915
Hugo_Intel
Hello karthikeyan
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry to hear that you are facing issues when trying to use Ubuntu with your Intel® Arc™ A770 Graphics.
Please note that at the moment the only supported Linux distribution is Ubuntu 22.04. More information in the following article: Where Can I Find Linux Drivers for Intel® Arc™ Graphics?
Could you please install Ubuntu 22.04 and check if the same issue persists? You can find the drivers in this link.
Hugo O.
karthikeyan
on the same PC I tried with win11 OS, before installing Intel® Graphics Driver 31.0.101.4091 I could see my system was using VGA basic adapter driver and display was working.
I am not sure what was the negotiated PCIe link speed.
After installing the driver(31.0.101.4091) I had black screen and it never came back. after 10minutes I force restarted my PC, but the display always goes black just after win11 boot screen.
I had to install another graphics card on another PCIe slot to peek in, and to my surprise this A770 card was reported as "Intel PCIe Upstream Switch Port - Vendor ID 8086-4FA0"
I have enclosed screen shot for PCI info dump. In the screen shot you could see card has negotiated x16.
karthikeyan
after uninstalling intel driver 31.0.101.4091 I am able to see Intel Arc A770 Graphics re-appearing with link width x1, but this link is negotiated between your internal switch, physically this card has negotiated x16 with my motherboard
karthikeyan
graphics driver installation log on win11
karthikeyan
this is a brand new card, so could you guys tell me if this card needs replacement because of HW issues?
Or is it some kind of software driver issue / compatibility issue ?
Hugo_Intel
Hello karthikeyan
In order to better understand this issue, could you please let us know the exact behavior that your system is experiencing? I see that you mention that the screen goes black after the Windows boot-up process. Does this always happen or do you have different issues with the GPU?
Also, please create a log file with the Intel® System Support Utility and attach it.
Hugo O.
Hugo_Intel
Hello karthikeyan
I hope you are doing fine.
Hugo O.
Hugo_Intel
Hello karthikeyan
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
Andres_Intel
Hello karthikeyan,
Before we close this thread, we want to let you know that this doesn't seem to be a defective graphics card given the information provided so far. The motherboard you have is not 100% compatible since as per Gigabyte's site it doesn't support Resizable Bar.
Reference: https://www.gigabyte.com/WebPage/785/NVIDIA_resizable_bar.html
Before thinking about defective hardware it would be recommended to test the card on a system that fully supports Resizable Bar and for further advice on this subject recommend contacting the motherboard manufacturer.
Andres P.
karthikeyan
With latest beta driver 31.0.101.4576 I am finally able to successfully install the driver along side of AMD RTX6800.
first boot after the driver installation was fine, but I had a few hiccups like
1. display orientation was in portrait mode instead of landscape.
2. weird latency, like 4-5 seconds while moving the mouse.
I had to unplug & plug the display port cable a few times to get these issues resolved.
