Hello, I have a problem with the ARC A750. When I stream TikTok Live and play League of Legends, my game sometimes crashes due to a gpu driver error. Additionally, the number of FPS is 70-80 at a resolution of 3440x1440. I'm a bit disappointed because 2070 Super raised to 144, I expected drops but not like this
Does anyone know what can be changed in the settings to make it work better?
Hello kaczorinax,
Thank you for posting on the Intel️® communities. We understand that you are experiencing issues when streaming and playing League of Legends.
To have a better understanding of your issue, please provide me with the following:
- When does the game crash? Is it when starting the game or in the middle of a game session?
- Do you receive any error messages? If so, provide me with a screenshot of the error message.
- Does the issue occur if you are only running the game without streaming?
- Do you have Resizable Bar enabled?
- Is the issue present with different driver versions?
- What is the step-by-step you follow to face this issue? It will help us with issue reproduction purposes.
- Create a report using the Intel
System Support Utility (Intel SSU). This report will gather information about your system, such as Operating System Built, Driver, BIOS versions, etc. - Download the Intel SSU
- Open the application and click "Scan" to see the system and device information. By default, Intel
SSU will take you to the "Summary View." - Click on the menu where it says: "Summary" to change it to "Detailed View."
- To save your scan: click "Next"; then "Save."
Jean O.
Hello kaczorinax,
We hope you are doing fine.
Jean O.
Hello kaczorinax,
Best regards.
Jean O.
