The problem has already been described in isue in the redot repository here: ARC B580 - Menus are sluggish in the redot editor. · Issue #921 · Redot-Engine/redot-engine
This issue is relevant for godot 4.4
Hello TeHbBoMpake,
Thank you for posting in Intel Communities! I understand that you are experiencing an issue with Redot and its compatibility with the Arc B580.
To assist you further, could you kindly provide the following details:
- What is the exact driver version you have installed?
- Have you tried using Display Driver Uninstaller (DDU) to completely remove and then reinstall your graphics drivers?
- When did the issue first occur?
- Is the problem consistent or intermittent?
Your clarification is greatly appreciated. Looking forward to hearing from you soon!
Ariel P.
Hello TeHbBoMpake,
I would like to follow up and ask if you've had the chance to review my previous response, where I asked a series of questions in order to better assist in finding a resolution for your issue.
Looking forward to your response!
Ariel P.
Hello TeHbBoMpake,
Ariel P.
I am having similar issues as well as tool-tips disappearing when I hover my mouse over menu items.
1. I am on driver version 32.0.101.6737
2. I did use DDU
3. It occurred from the first day I got my B580.
4. The problem is constant.
I hope this helps find a solution, if I don't get a reply I will submit my own ticket. TY c:
