Intel® ARC™ Graphics
3310 Discussions
ARC a730m driver is performing poorly
chrysalis
PC GAME《The Last of Us》,The graphics driver is not performing well in this game, with graphics usage at about half the rate and very low frame rates even with the lowest game settings
Jean_Intel
Hello chrysalis,
Thank you for posting on the Intel️® communities. We understand that you are having performance issues when playing The Last of Us.
  • What is the game resolution setting you are using?
  • Does the issue persist on different driver versions?
  • What is the games distribution service? ( Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect).
  • Share a video showing the issues you are experiencing and a screenshot of the graphics settings.
  • Create a system report using the following applications:
  • Intel System Support Utility (Intel SSU)
    • Download the Intel SSU
    • Open the application and click on "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click on "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello chrysalis,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello chrysalis,
Best regards.
Jean O.
