I really need your help . I purchased this laptop like a week ago, and whenever i update the latest driver for INTEL GRAPHIC CARD from the website ( updating as requested by Intel Driver assistance) my screen is starts flickering black and cannot do anything just reinstall the windows 11 again. I attached some pictures of the screen and of the update. Whenever I install that update after the system is rebooted my screen is gone until a new OS is installed. I have also tried with DRIVEFIX to update the driver and the update fails everytime..... I cannot even installing with DRIVEFIX.
You should be using only the drivers from ACER, not the intel generic driver.
I used the driver from acer.com, the Intel Driver support assistant requested me that update.
I am sorry for the pictures that was attached above, i didn t know it had that resolution. Here is the driver with the trouble INTEL ARC IRIS XE GRAPHIC WHQL
Hello Alex1312
Thank you for posting on the Intel® ARC™ Graphics Communities. I am sorry that you are experiencing display issues when updating the driver through the Intel® Driver & Support Assistant (Intel® DSA) tool.
Following the recommendations provided by @AlHill, I would recommend staying with the driver provided by your system manufacturer since these drivers are optimized and customized for your system's hardware. Based on the Acer website the latest version they offer is 31.0.101.3302.
As for the update coming from Intel® DSA, you can follow the following instructions to stop receiving that specific update:
Hugo O.
Hello Alex1312
I hope you are doing fine.
Let us know if you have further questions.
Hugo O.
Hello Alex1312
I have not heard back from you. So I will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Hugo O.
