My Sparkle Guardian Arc B570 is underperforming against posted benchmarks by about 30% and the only thing I can find that's awry is that it doesn't ever seem to draw over 70W from my power supply (as per both Intel Graphics Control and GPU-Z). I just upgraded from a Radeon 5600 that was performing dutifully. Power supply is 600W and I don't have anything unusual that would be loading it down. ReBAR is enabled.
Are there any controls or BIOS options I might be overlooking that could be capping my power consumption? Could it be a hardware defect?
I'm also running into this issue and I don't know if it's related: https://community.intel.com/t5/Graphics/B570-not-recognizing-all-XE-cores/m-p/1659042
Hi DenwaRenji,
I'm sorry to learn that you are experiencing issues with your Arc B570. To better assist you and determine the most appropriate resolution, could you please provide the needed details listed below:
- May I know if your Arc B570 is working as intended before?
- What are the changes before you encounter this issue?
- What Benchmarking Application are you using?
- Have you already tried updating your Graphics driver version to the latest one (32.0.101.6557/32.0.101.6262)?
- Download link: Intel® Arc™ & Iris® Xe Graphics - Windows*
- Have you already tried performing DDU first before downloading the latest drivers?
Once we have this information, we will be able to proceed with the next course of action and work towards resolving the issue you are facing.
Earl E.
Hi DenwaRenji,
Earl E.
Hi DenwaRenji,
Earl E.
