Intel® ARC™ Graphics
2089 Discussions
Ausu Rog B550 F gaming WIFI
Pitwolf
Morning, I bought an Intel A770 sparkle graphics card board while they were on sale during thanksgiving. I knew this was a startup and waited a year to get the bugs out, but as Im see the bug are still there. So here is whats going on...
1st I update the BIOS which in itself was a major pain. My board is a ASUS B550 F Gaming (wifi). The gaming part and the wifi make a difference apparently, because it would not take any of the bios upgrades.
Reinstall of Widows 10, complete install. Previous windows was in place since late 2020, with 2 bugs that I could not get removed.
That fixed, Bios upgraded to was from 1004 to 3404, the card would not post until I went into Bios and reset CSM every time I powered up. Even to the point to completely turn off the power supply to the bios. And even then the games would run, Anno 1800, and Path of exile great no issues but sometimes BSOD. Restart as mentioned above for a restart. So yesterday, I down graded to a bios, I read an article that said it ran fine on 3004. So today the same this is going on but not as severe, but it did take a complete power down this morning.
Before this board, I had a RX5600xt, bought during a video card panic 2020, it was the only one not $650 or better. It has ran flawless, and has the motherboard board as well, even when running eve online with 4 accounts running the card did great. But I started seeing issues with the card in the last year or so. So I upgraded to the arc.
Im using Belarc advisor for specs..
Windows 10 Home build 19045.3803
Boot Mode UEFI with secure boot disabled
AMD Ryzen 7 3700X 8 core
Bios UEFI 3002 02-23-2023
Ram 32 gigs
Samsung SSD 970 EVO 500 gig
WDC WDS100T2BOA
Smart Healthy both
Intel Arc A770 Graphics Display adapter
2 Monitors both LG
Intel drivers is
Intel Arc control version 1.73.5335.2
Driver Version 31.0.101.5081
Just need to have a stable card with out the daily let power down or the daily trip to the bios...I dont leave the machine running like others do, I do a shut down through the software. I need a path to take to get this resolved...see attached file for logs from Arc software. That was the last one from today.
Andres_Intel
Hello Pitwolf,
Thank you for your response and for completing the steps.
Seems the BSOD issue is a different one, to keep this thread organized and help you in the best way, I recommend you open another thread for that issue.
I will start with an investigation to provide you with the next steps and as soon I have further information I will let you know.
Andres P.
Pitwolf
Also I did down load the SSU program and here is the results...
Andres_Intel
Hello Pitwolf,
Thank you for posting on the Intel communities. I will be more than happy to help you. Given that you are experiencing power down issues with your Intel® Arc™ A770 Graphics. In order to enhance comprehension of the circumstances, kindly respond to the following inquiries:
Andres P.
Pitwolf
Completed DDU and Driver install. Let me know. Also a software package was installed as well...Driverupdate, came from your link that was posted on the response.  Was that suppose to happen??
Bandit8623
New Contributor II
@Pitwolf
csm should be disabled.  4g enabled and rebar enabled.  in bios
Pitwolf
I wish that was true, this morning it does it again, only after I went back in and disabled CSM and turned on re-sizable bar did it boot.
Andres_Intel
Hello Pitwolf,
Thank you for completing the previous steps.
The clean installation with DDU helps to remove files of the previous drivers that may affect the functionality of the graphics card, if the issue persists after the previous steps, please follow the ones below:
  • Update the BIOS to version 3404 again, I understand you did it before, but we recommend having the system up to date, since this may help to improve stability, functionality, and compatibility.
  • If possible, test other 1x8-pin & 1x6-pin cables, to check if the root of the issue is the cable.
  • To know if the power supply meets the requirements to work with the graphics card, can you provide me with the make and model?
Andres P.
Pitwolf
K will do on Bios, I did not mention that the cable has been tested between this card and my other card. And now as of this morning it start to have a driver issue, BCOD during game play, not 1 but 3 time in the past 2 days. And btw I have 2 -4 pins connections on card.
Pitwolf
So the booting issues seems to have worked itself out. But during game play today and this is the first Ive seen this Issue, "unable to find device". It flashed and then blue screen of death happened. I switch to Vulcan instead of directx12 after a reboot and it was working not as smooth as directx but working. Im playing Path of exile....
Andres_Intel
Hello Pitwolf,
Andres P.
Pitwolf
Thx for your help...
Andres_Intel
Hello Pitwolf,
Thank you for your time.
I have been working on the investigation, and there is one more step we can do, to verify if the root of the issue is the graphics card or the motherboard.
  • Test the graphics card in another compatible system.
Please let me know the results.
Andres P.
Andres_Intel
Hello Pitwolf,
Were you able to test the graphics card in another compatible system to check if the behavior is the same?
Andres P.
Andres_Intel
Hello Pitwolf,
Andres P.
