Intel® ARC™ Graphics
3469 Discussions
B580更新了5月31日的驱动程序后出现浏览器bug
Jimmy_Fantasy
更新之后,使用edge浏览器浏览微博时,滚动页面会出现花屏乱码
shanatan
你可以尝试把microsoft edge或者任何浏览器高级设置中的‘启用硬件渲染’这个选项关闭来暂时规避这个问题。
You can try closing the "Enable hardware rendering" option in the advanced settings of Microsoft Edge or any other browser to temporarily circumvent this issue.
However, we hope the Intel Arc Graphics Driver Team can fix this issue soon.
shanatan
martinpawlak
that is the same problem that GlouriousEggroll change the standard browser in his Nobara 42 Linux Distribution from Firefox to Brave Browser.
In the changelog , he also explains why they switched from Firefox to Brave.
Brave was not our first or immediate choice, but the decision to switch to Brave came after a long period of testing with various browsers that failed in one way or another. Firefox and Firefox-based browsers (such as Floorp and LibreWolf) caused a GPU crash when scrolling live video (e.g. YouTube Shorts, TikTok, etc.) with VRR enabled: https://gitlab.freedesktop.org/mesa/mesa/-/issues/12528 Chromium and Vivaldi crashed Google Meet with hardware acceleration enabled (their flatpaks worked fine though).
In the end, Brave was the only one that didn't crash in all of this and also didn't require external/system packages to enable codecs for video playback.
Best regards
ArchieD_Intel
Hi Jimmy_Fantasy,
  • When did the issue start? Was it after a specific update?
  • What are the troubleshooting steps that you tried so far?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
Additionally, to gain a comprehensive understanding of your system, please use the System Support Utility (SSU). This tool will generate a text file compiling all your system information. You can follow the instructions at this link and send the text file here. Help Guide for the Intel® System Support Utility.
If you have any questions, please let us know.
Thank you for your suggestion shanatan.
Archie D.
Jimmy_Fantasy
我关闭了edge硬件加速功能之后就没再出现花屏现象,开启之后又出现了,
我的配置是 14600kf+b580。使用了英特尔·显卡驱动程序 32.0.101.6874版本之后出现的情况,
升级驱动时我选择了清洁安装。
ArchieD_Intel
Hi Jimmy_Fantasy,
I'm glad to know you found a solution, thank you for taking the time to share this fix, and hopefully, it may help other community members experiencing similar behavior.
Since the thread is now solved, we will proceed to close it. Please keep in mind that this thread will no longer be monitored by Intel. Thank you for your understanding.
Archie D.
