Intel® ARC™ Graphics
2414 Discussions
CS2'FPS IS TOO LOW LOW LOW ,THE MOST PLAYERS IN THE WORLD.WHY IS THIS SO?
CS2FPS
A770 GRAPHICS card,3dmax spy time running points is14000+,but cs2'fps is too low.
ACarmona_Intel
Hello CS2FPS,
Please provide the following information in order for us to isolate the issue and provide you with a solution:
  • When did the issue start, and have you made any changes that might cause the issue?
  • What are the brand, model, and wattage of your power supply so we can check if it meets the arc power supply requirements?
    • Intel® Arc™ A770 Limited Edition and A750 Limited Edition Graphics:
      • Minimum 600W power supply with two PCIe power connectors (1x8-pin and 1x6-pin)
  • Please generate an SSU report to help me further analyze important details on your system, such as the OS build number, graphics driver version, errors logged in the system, etc. To generate the SSU report, please refer to the article How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
  • Resizable BAR is important as it enhances the graphics card's performance. Was it enabled in the BIOS? To check, please follow this article: What Is Resizable BAR, and How Do I Enable It? (intel.com)
We look forward to your response!
Thank you, and have a great day ahead!
Carmona A.
ACarmona_Intel
Hello CS2FPS,
We are checking in with you on the A770 issue we are having to see if you already have the answers to our query so we can further isolate our issue.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello CS2FPS,
We are checking in with you on the A770 issue that we have, as we have not heard any response from you.
Carmona A.
ACarmona_Intel
Hello  CS2FPS,
We have not heard back from you, so we will close this enquiry now. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Thank you, and have a great day ahead.
Carmona A.
