Intel® ARC™ Graphics
2429 Discussions
CS2 Performance, low FPS with A750
Xzorn
I've recently tried to play cs2 with a friend. I haven't played the game for a long time.
But the performance is crap.
I get like a avg fps of 80-90.
sense the -vulkan mode no longer works for Cs2 I've don't have that.
I've tried too search for some graphics settings with the A750 for the game. but naa, runs better after that, band got a little bit more stable FPS but still around 80-90 FPS.
Is there a solution out there and are someone else experiencing this problem?
Attached files for Intel's convince, both SSU and a screenshot of my in game settings.
JedG_Intel
Hello Xzorn,
I understand that you are experiencing performance issues with CS2 and I appreciate your effort for sharing the game settings as well as SSU report. Please share the additional information below so I could investigate this matter further.
1. Is the issue isolated to CS2?
2. Have you tried lowering the game settings to see if that would make any difference?
3. Are there specific maps wherein the FPS drops?
4. What average FPS are you getting previously?
I look forward to your response!
Jed G.
Xzorn
Hi Jed G.
Thanks for the reply.
Answers to your questions
1. yeah, I would say that. I don't play any other FPS game at the moment were there is a high FPS demand.
(I play the withcer 3 on ultra and getting like 70-80 FPS in 1440p)
2. Just did, got it up to an avg of 105 FPS om lowest settings in 1080p. jo playable but not at all ok, like a crap laptop.
3. No
4. 105 on low in 1080p
Thats the problem, the card should preform like around avg 200 fps witch would be great to that I have a 165hz screen so I can get the max out of it in this type of game.
I can try an old game like Payday 2 to see what the performance is in that.
JedG_Intel
Hello Xzorn,
Thank you for sharing all this information. For further troubleshooting, please try to follow the steps below.
1. Close background processes
 - Use the Task Manager (shortcut: CTRL+SHIFT+ESC), then click the CPU and Memory tabs to see what’s using large chunks of your CPU or RAM.
2. Update the game
 - Developers often release patches with major performance impacts. Enable automatic updates in Steam
3. Repair your install
 - try accessing the game’s properties in your library and find the “Repair” or “Verify Integrity” option.
4. Swap test the graphics card if possible.
Should you encounter the same issue after following the above recommendations, please let me know.
Jed G.
oldmagic
I also have very bad performance in cs2 with my Intel Arc A750.
The FPS goes from 100-250 down to as low as 50 fps sometimes and just drops betweens these numbers all the time.
No matter what i do i can't get a stable fps.
CPU: AMD Ryzen 7 5800X 8-Core Processor 3.80 GHz
RAM: 32G DDR4 3600
GFX: Intel Arc A750
HDD: Nvmv 1TB Samsung.
Note: Reinstalled Windows 11 maybe 2-3 weeks ago.
I don't know if the GFX is also causing bluescreens, cause that happens alot for me.
Let me know if i'm doing something wrong here.
JedG_Intel
Hi Xzorn,
I'm checking in to see if you were able to follow the recommendations that I posted. Please let me know at your earliest convenience so we can determine the best course of action to resolve this issue.
Hello @oldmagic,
I understand that you're also having an issue with Counter Strike 2. For us to assist you properly and to avoid confusion, please create a separate thread.
Jed G.
JedG_Intel
Hello Xzorn,
Jed G.
Xzorn
Hi JedG,
Yeah I've tried that and got some good results.
But there is still some fps drops that I feel like the system should be able to run on a better setting.
I got a avrg at around 200fps, and got a lot of drops down to 80-100fps.
So yeah, it's playable. but that's it.
On the lowest settings, turning of everything on the computer.
that's not like a big woop if you know what i mean.
Unfortunately I don't have another GPU to change to except an old 970 and the time to do that I don't feel like putting in regarding all the other problems I've had with the update and such.
Ty for reply!
