Intel® ARC™ Graphics
2778 Discussions
Can't see arc b580 in bios but can be seen in hwinfo64
Kentmclovin
Almost 80% of the time when I start the PC I will get no display on b580 but on my igpu.
I just build the PC and this has been a problem from the beginning.
Motherboard is a620m-k (not updated)
AMD Ryzen 5 7600x
I cant find the gpu inside the bios.
JedG_Intel
Hello Kentmclovin,
For me to address your concern properly, please share the information below.
1. What is the make and model of Power Supply?
2. When you say 80% of the time, does that mean you're able to have display using Arc B580 sometimes?
3. Which display cable are you using?
4. Is this issue present from the start of using Arc B580?
Please also generate SSU report for me to check your system components and configuration.
Jed G.
JedG_Intel
Hello Kentmclovin,
Jed G.
JedG_Intel
Hello Kentmclovin,
Jed G.
