Intel® ARC™ Graphics
2038 Discussions
Can't we get more performance out of Granblue Fantasy: Relink?
DanSun
There are no particular problems with Granblue Fantasy: Relink.
However, when I go to a village or other places, the frame rate seems to drop significantly.
Above all, even though the GPU rendering performance is sufficient, it cannot be used to its full potential, which makes it seem like this game is not performing well because it is a Direct 11 game.
Can’t they come out with an optimized driver to provide better Intel Arc performance?
RamyerM_Intel
Hello DanSun,
Thank you for posting in our community.
We apologize for the fps drop that you are experiencing in the game. We have received reports of this issue before and I want to let you know that we are currently working on it. Although there is no specific timeline yet, I can assure you that we are aiming on optimizing the driver for the Granblue Fantasy: Relink.
Ramyer M.
RamyerM_Intel
Hello DanSun,
I'm reaching out to you again to ensure that we capture the exact information that can assist us in determining the solution. Please provide the following:
1. Model of your Arc GPU
2. The exact driver version that you're using when you've encountered the low FPS issue.
Ramyer M.
DanSun
RamyerM_Intel
Hello DanSun,
Thank you for sharing this information as it is helpful to identify which products and drivers need improvement. We will continue working on a fix for this issue and please check our Arc graphics download page regularly for updated drivers and/or our post about updates to this thread.
Ramyer M.
Esteban_Intel
Hi @DanSun,
A possible fix for this issue is included with driver version 31.0.101.5379. Can you please install this version and test it out?
DanSun
I am very satisfied with the performance improvement.
Thank you for your hard work.
