Intel® ARC™ Graphics
3469 Discussions
Driver 32.0.101.6129 for Intel Arc a750 works far better than current drivers for MHWilds
Rubick1
I saw it on Reddit and tested it, it has less stuttering and more FPS, Id like it to be of help for a future driver update
JeanetteC_Intel
Hello Rubick1,
To get better understanding, please help me with the following details below:
1) As per my understanding, your ARC A750 GPU works better with driver version 32.0.101.6129. Can you confirm that you already tried the latest version (32.0.101.6647) and get more stutters than your preferred older version mentioned above?
2) To be able to help better, please describe briefly the actual issue you experienced with ARC A750.
3) Is this an out-of-the-box issue for your ARC A750 or it works fine before?
4) Please help share your configuration so I can further check the possible root case of the problem. This could be possible by downloading the Intel® System Support Utility for Windows* software. When the download is complete, launch SSU.exe.
  • Click Scan.
  • Click Save (.txt). *Attach the file as you reply
I will wait for your reply.
JeanetteC.
CodeKnight
I personally tested the latest driver version (32.0.101.6647). When running Monster Hunter: Wilds, the GPU utilization almost stagnated at 100%, and the FPS was mostly below 30.
After downgrading the driver to version (32.0.101.6129), under the same settings, the GPU utilization fluctuated between 80-100%, and the FPS was relatively stable at 30.
I have been using the A750 graphics card for about six months to a year.
我親自測試最新版本的驅動程式(32.0.101.6647)
運行Monster Hunter: Wilds時,GPU使用率幾乎停滯在100%
FPS幾乎都在30以下
之後我降級驅動程式(32.0.101.6129)
運行相同設定環境下,GPU使用率變成浮動80-100%
FPS相對穩定在30
我使用的A750顯示卡已經半年至一年左右
JeanetteC_Intel
Hello Rubick1,
Let us know if you have any questions.
JeanetteC.
JeanetteC_Intel
Hello CodeKnight,
I understand that you are facing exactly the same issue with Intel® Arc™ A750 Graphics when running Monster Hunter: Wilds. However, I kindly request that you create a new thread for your case. This will allow us to focus on your specific problem and provide you with better assistance.
Sincerely,
JeanetteC.
JeanetteC_Intel
Hello Rubick1,
As I haven't heard back from you lately, I will proceed with closing this thread. If you need assistance in the future, please start a new inquiry, as this thread will no longer be monitored.
Sincerely,
JeanetteC.
