Intel® ARC™ Graphics
2436 Discussions
External Monitor Resolution Limited to 1080p on ASUS MX27AQ with Lenovo Yoga Pro 9 16IMH9
Nathan_778
General info:
Graphics Driver Information:
  • Driver Version: 32.0.101.5763
  • Latest Driver: Confirmed using the latest WHQL driver
System Information:
  • Processor: Intel(R) Core(TM) Ultra 9 185H 2.30 GHz
  • Motherboard: Lenovo Yoga Pro 9 16IMH9
  • RAM: 64,0 GB
  • Operating System: Windows 11 Home
  • Power Supply: 175W
Issue Description:
When connecting my ASUS MX27AQ monitor (which supports 2560x1440 resolution) to my Lenovo Yoga Pro 9 16IMH9 laptop via HDMI, the maximum available resolution in Windows settings is capped at 1080p (1920x1080). This occurs even though the monitor’s specifications clearly support 1440p (2560x1440). Windows lists 1080p as the "Recommended Resolution."
Steps to Reproduce:
  1. Connect the ASUS MX27AQ to the Lenovo Yoga Pro 9 16IMH9.
  2. Go to Windows Display Settings.
  3. Observe that the maximum selectable resolution is 1080p.
Additional Information:
Please advise on potential driver or configuration solutions to enable full resolution support for my external monitor.
Nathan
MUC
Valued Contributor III
Lenovo Yoga Pro 9 16IMH9 - Product Specifications Reference
1x USB-C (USB 20Gbps / USB 3.2 Gen 2x2), with USB PD 3.0 and DisplayPort 1.4
1x USB-C (Thunderbolt™ 4 / USB4® 40Gbps), with USB PD 3.0 and DisplayPort 2.1
1x HDMI 2.1, up to 4K @ 60Hz
ASUS Designo MX27AQ
2560 x 1440 @ 60 Hz
1 x DisplayPort 1.2
3 x HDMI
Lenovo HDMI port compatibility may be limited to video formats defined by the Consumer Technology Association according to the CTA-861 standard.
Since the monitor is already 10 years old in terms of technology, please connect it via DisplayPort protocol using one of these cables:
MUC
ASUS Designo MX27AQ
2560 x 1440 @ 60 Hz
1 x DisplayPort 1.2
3 x HDMI
Nathan_778
Hello Muc,
I saw that the drivers for my monitor which I could find online were only available for windows 10 and earlier, maybe this was the problem because my other computers run windows 10 and my newest laptop runs on windows 11. Sadly I am not able to test out a displayport cable because my laptop does not have one and i don't own a dongle.
I just ordered a new 2.5K screen which i connect through usb-C and it shows the propper resolution.
Thanks for the help !
Kind regards,
Nathan
