Intel® ARC™ Graphics
Avisos
3387 Discusiones
For Intel Engineers and Intel Support
addelucas123
Nuevo Colaborador II
2.803 Vistas
Buenas noches
I am David and I greet you from Spain, I come to say thank you very much for the Intel drivers or developers and support engineers, what do you mean by that, Cyberpunk 2077 has just implemented its Intel XeSS 1.1 technology as much as you and I have been able to overcome and implement it , now there is a lack of performance improvements in both Cyberpunk 2077 and red dead redemption 2, remember that red dead redemption 2 using DX12 launches 1 FPS vertical sync enabled and 144Hz FULL HD, remember to correct and also performance.
Anyway, I come to say thank you for the implementation of Intel XeSS Cyberpunk 2077, now the last one is missing, which would be red dead redemption 2 that implements this Intel XeSS technology.
Remember that we must improve the performance and problem when you activate 144Hz and vertical synchronization gives 1 FPS Red Dead Redemption 2 DX12 that remember that it is reported and you must correct.
Cyberpunk 2077 only lacks performance improvements and we want that game to go smoothly, that is, 115 and 120 FPS 1920x1080, surpassing the RTX 3060 Ti. On the other hand, remember, thank you very much for implementing intel xess in the game, good for there and good for everyone the Intel team and engineers, but remember the reports
5 Respuestas
Jean_Intel
Empleados
2.747 Vistas
Hello David1997,
Thank you for posting in the Intel Communities. We are at your disposal to help you with your issue.
It is important to mention that Intel is working closely with leading game engine providers to integrate XeSS. However, not all games that support Super Sampling can use Xe Super Sampling. The game developer needs to confirm if XeSS is supported.
Jean O.
addelucas123
2.741 Vistas
Good night
I'm David, Ok if I would like you to implement Intel XeSS or Super Sampling to implement in red dead redemption 2 we are missing the latest video game technology which is red dead redemption 2, I am waiting for the update on the problem we are having with the network dead redemption 2 and cyberpunk 2077
Jean_Intel
Empleados
2.731 Vistas
Hello David1997,
We will proceed to check the issue internally and post back soon with more details.
Jean O.
addelucas123
2.721 Vistas
Good night
Remember the previous messages, the red dead redemption 2 and Cyerbpunk 2077 have already been reported and you are waiting for the intel, that is, the intel driver engineers, to put in those drivers to be able to play DX12 in a way 60 FPS even above
Jean_Intel
Empleados
2.640 Vistas
Hello David1997,
Thanks for your patience.
After reviewing this matter internally, we can confirm that we are still investigating this matter, and you should wait for a fix in a future driver version. Also, as we mentioned previously, the implementation of XeSS is up to the Game developers. We can work with them to optimize it, but the developers have the final word.
Since we are working on this issue, we will close this thread now. If you need additional information, please submit a new question, as this thread will no longer be monitored.
Jean O.
Responder
