Intel® ARC™ Graphics
1162 Discussions
GamePP DX12 Benchmark can't working on Arc A730M
YiLin1
CreateCommittedResource(&CD3DX12_HEAP_PROPERTIES(D3D12_HEAP_TYPE_READBACK),
D3D12_HEAP_FLAG_NONE,
&desc,
D3D12_RESOURCE_STATE_COPY_DEST,
nullptr,
nullptr);
desc = {D3D12_RESOURCE_DIMENSION_BUFFER, 0, 1600, 1, 1, 1, DXGI_FORMAT_UNKNOWN, {1, 0}, D3D12_TEXTURE_LAYOUT_ROW_MAJOR, D3D12_RESOURCE_FLAG_NONE}
This buffer type is GPU to CPU. But in the third Frame after the start, buffer->map failed.
Software URL:<removed>
PCScore->GPU Benchmark
Labels (2)
Robert_Q_Intel
Hello YiLin1,
Thank you for posting on the Intel Arc communities.
To start troubleshooting the issue that you are reporting we would like to gather the following information with you:
  • What are the conditions that are required in order to recreate this issue, please share the tools and steps.
This information will enhance our research in order to find a solution to this issue
Robert Q.
Robert_Q_Intel
Hello YiLin1,
Robert Q
YiLin1
Hi Robert Q,
I replied to the information you need.
Yi Lin
YiLin1
Hi Robert Q,
The Steps:
 1. Download GamePP GPU Benchmark Demo or GamePP.
 2. If you download GamePP GPU Benchmark Demo, just run Launcher.exe in CMD/PowerShell, Launcher.exe -r meanings DX12 RayTracing.
 3. If you download GamePP, you need to open PCScore -> GPU Benchmark.
GamePP Website
The Intel® System Support Utility for Windows "Everything" and save the resulting .txt is attch.
The Driver gfx_win_101.3490 can run without error, but the screen flickers.
The Driver gfx_win_101.3793  buffer->map failed come back.
Yi Lin
Robert_Q_Intel
Hello YiLin1,
Thank you for the information.
We can see that the device is currently running on the following intel Graphics driver: 31.0.101.3490 which is an older version of the ntel® Arc™ Graphics Windows* DCH Driver.
Perform a clean update to the latest version of the Intel® Arc™ Graphics Windows* DCH Driver by following these steps:
We can also see that you are running on the BIOS version MACHENIKE G1IB037, 08/30/2022 12:00 上午, make sure this is the latest version.
Once these steps are completed please test the benchmark and share the outcome with us, and attach screen captures of the outcome or any error messages.
Robert Q.
YiLin1
Hi Robert Q,
 I use the new ARC Driver, but it's still screen flickers.
You need to download GamePP GPU Benchmark Demo  and run Launcher to check what happen.
My laptop BIOS Version is already the latest version.
Yi Lin.
Robert_Q_Intel
Hello YiLin1,
Robert Q
Robert_Q_Intel
Hello YiLin1,
Thank you for posting,
We will check this internally and we will get back to you as soon as we have more information.
Robert Q.
Robert_Q_Intel
Hello YiLin1,
We are still working on replicating this issue,
In the meantime please let us know if during your testing the Resizable Bar was enabled in your system's BIOS?
In case you are not familiar with the resizable bar option please visit the following reference article:
What Is Resizable BAR and How Do I Enable It?
https://www.intel.com/content/www/us/en/support/articles/000090831/graphics.html
Robert Q
Robert_Q_Intel
Hello YiLin1,
Robert Q.
Robert_Q_Intel
Hello YiLin1,
We are working on replicating this issue, to continue we would like to confirm the following information:
Does this type of error appears only in the benchmark or are you experiencing similar issues in different applications such as videogames?
Please record a video of the issue and share it with us.
Additionally, you can download the latest version of the Intel® Arc™ Graphics Windows* DCH Driver - BETA in order to test if the issues persists in this version:
https://www.intel.com/content/www/us/en/download/729157/intel-arc-graphics-windows-dch-driver-beta.html
You can follow this guide to complete a clean installation:
Clean Installation of Intel® Graphics Drivers in Windows*:
Robert Q.
YiLin1
Hello Robert Q,
  1. The Resizable Bar was enabled on the GPU-Z.
  2. Currently, this type of error occurs 100% of the time in Benchmark, but only occasionally in other games.
  3. I still have this problem with beta drivers.
Yi Lin.
Robert_Q_Intel
Hello YiLin1,
Thank you for your response.
We will continue to work on this issue internally, we will get back to you as soon as we have more information.
Robert Q.
Robert_Q_Intel
Hello YiLin1,
Thank you for your waiting time.
Recently a new driver was launched for Intel® Arc™ the driver version 31.0.101.4032.
Please install the latest driver version and run the benchmark.
Download link for the latest driver:
Intel® Arc™ & Iris® Xe Graphics - WHQL - Windows*
https://www.intel.com/content/www/us/en/download/726609/intel-arc-iris-xe-graphics-whql-windows.html
Here you can find a guide to help you complete the installation:
When we try to run the GamePP GPU Benchmark Demo via Command Prompt with parameter -r it fails stating Ray Tracing is not supported.
Please record a video replicating the issue and share it with us.
Robert Q.
YiLin1
Hello Robert Q,
  the following video is recorded with Intel® Arc™ the driver version 31.0.101.4032 in Command Prompt Run Launcher.exe to starting demo.
for example:
C:\Windows\System32>cd D:\GamePP_GPU_Benchmark\Benchmark
C:\Windows\System32>D:
D:\GamePP_GPU_Benchmark\Benchmark>Launcher.exe -r
D:\GamePP_GPU_Benchmark\Benchmark>Launcher.exe -r --fullscreen
D:\GamePP_GPU_Benchmark\Benchmark>Launcher.exe --fullscreen
-r means Open RayTracing Mode.
--fullscreen means Open FullScreen Mode.
Yi Lin
Robert_Q_Intel
Hello YiLin1,
Thank you for posting we really appreciate it.
After reviewing the video it seems as though the video is showcasing the driver version installed on the device,
We are unable to observe the error messages, in case you are using more than one display make sure to be using only one at the time of recording,
  • Please record again a video showing the steps to follow in order to trigger the issue using GamePP GPU Benchmark Demo.
Robert Q.
YiLin1
Hello Robert Q,
  The attached video shows the system information, the graphics card driver version, and the GamePP GPU Benchmark Demo starting up.
  The main problem is that the picture is flickering and confusing.
  In order to ensure that the video does not exceed the size of the uploaded file, I pressed Esc to end Benchmark, and did not record the whole process of Benchmark.
Yi Lin
YiLin1
Hello Robert Q,
  One more piece of information, GamePP GPU Benchmark uses DirectX Raytracing, DirectX Raytracing Feature Test requires Windows 10 version 2004 or later.
Yi Lin
Robert_Q_Intel
Hello YiLin1,
Thank you for the details.
We are working on it at the moment
As soon as we have the results of our testing we will share them with you.
In case you have more information please let us know.
Robert Q.
Jean_Intel
Hello YiLin1,
We appreciate your patience.
Thanks to your reports, we reproduced the issue. It has been reported to our driver debug team bug ID 22016494146. Unfortunately, we can't commit to any outcome or time frame yet, but we will address this in future driver updates.
Note that if you need any additional information, submit a new question, as this thread will no longer be monitored.
Jean O.
