Intel® ARC™ Graphics
2454 Discussions
Games freeze for a few seconds when action is happening
Minewar
I got an Arc A770 end of last year, and at that point had pretty big performance problems, as i had an Ryzen 7 2700x, which is not supported.
I now recently upgraded my CPU and motherboard, to accomodate for the Arc A770, but i still have performance problems.
In nearly every game i play the game stutters quite drastically, as well as freezes or lags pretty strong, when some action is happening on screen. This is really frustrating as i bought the CPU and motherboard specifically to improve performance.
Another weird performance issue is the performance tanking, while a single thread of the CPU is at 100% and the GPU at 40%-60%
ReBar is enabled in the BIOS.
My Specs are:
Intel i5-12400F
Intel Arc A770
MSI PRO B660-A DDR4
G-Skill DDR4 3200MHz
650W PSU
Windows 11
What i tried:
-Uninstalling GPU drivers using DDU
-Trying out older drivers
-Installing the Chipset for the MB
-Completly reinstalling windows
-enabling XMP
Jean_Intel
Hello Minewar,
Thank you for posting on the Intel️® communities. We understand your frustration with the issue you are experiencing, we understand that you expected an issue improvement by upgrading your system with recommended hardware for Arc Products.
To have a better understanding of your issue, please provide me with the following:
  • What are the games affected by this issue?
  • Are you experiencing the same issue on all the games you have tried?
  • You mentioned that the issue occurs when action is happening, but what do you mean exactly by that statement?
  • What are the games distribution service? ( Blizzard, Epic, Origin, Steam, Xbox, Ubisoft connect)?
  • Provide us with a video showing the issue behavior, as well as the game settings you use.
  • We would like to gather more information about your system that will help us troubleshoot your issue, so please, provide us with a report using the following programs:
    •  Intel System Support Utility (Intel SSU):
    • Open the application and click "Scan" to see the system and device information. By default, Intel SSU will take you to the "Summary View."
    • To save your scan: click "Next"; then "Save."
  • Intel® Graphics Command Center:
    • Open the Intel Graphics Command Center
    • Navigate to the Support tab
    • Select System Diagnostic
    • Click Generate Report
    • Select Save and name the output file.
Jean O.
Jean_Intel
Hello Minewar,
Jean O.
Jean_Intel
Hello Minewar,
We hope you are doing fine.
Jean O.
Jean_Intel
Hello Minewar,
Best regards.
Jean O.
