Intel® ARC™ Graphics
2870 Discussions
Granblue Fantasy:Relink游戏崩溃
itsakuya
我的环境是Arc750+Windows10,通过DDU卸载了旧的驱动程序版本后,安装了31.0.101.5445,Arc750的所有设置都是默认值
该游戏的分辨率是窗口的1600 x 900,其它图像设置也是默认值
游戏崩溃的原因无法确定,这次崩溃有以下特征:
1.没有任何错误提示,游戏卡住一会后自动关闭
2.在任务中的战斗场景触发
3.崩溃时间无法确定,可能几分钟就触发,也可能几个小时都不触发
4.在31.0.101.5333的驱动程序版本中从未出现,从31.0.101.5382至31.0.101.5445的驱动程序版本中开始出现
out.mp4显示了游戏崩溃的时间在02:12
ACarmona_Intel
Hello Itsakuya,
请注意,我只能用英语支持您。 我使用网络翻译工具翻译了这个答案,所以可能有不正确的翻译
We will do further investigation into our issue and post the response on this thread once it is available.
Thank you for understanding.
Carmona A.
ACarmona_Intel
Hello Itsakuya,
Thank you so much for patiently waiting for our response.
We have conducted tests with the Intel® ArcTM A750 Graphics and driver versions 31.0.101.5445, 31.0.101.5382, and 31.0.101.5330; no crashing issues were encountered while using high and ultra settings.
To assist us in our ongoing investigation, it would be greatly appreciated if you could share a screenshot or screen recording of your graphics settings. This will enable us to replicate the environment more precisely and work towards a resolution.
Carmona A.,
itsakuya
我的游戏设置:
我的Arc750控制面板设置:
崩溃时间是随机的,和游戏运行时长无关。
itsakuya
我尝试了新版本31.0.101.5518,玩了6个多小时没问题,关闭游戏后,再重新启动游戏,在任务中战斗一会,游戏就崩溃了,新版本和上述旧版本存在同样的问题
游戏长时间没崩溃的情况,我就会重启游戏再测试
ACarmona_Intel
Hello Itsakuya,
We would like to know if it's possible that you could share a screenshot or screen recording of your graphics settings. This will enable us to replicate the environment more precisely and work towards a resolution.
Thank you, and have a great day!
Carmona A.
ACarmona_Intel
Hello Itsakuya,
Again, we would like to know if it's possible that you could share a screenshot or screen recording of your graphics settings. This will enable us to replicate the environment more precisely and work towards a resolution.
Carmona A.
itsakuya
我已经提供了游戏的图形设置的截图和控制面板的图形设置的截图。
这些不是你们需要的吗?我想知道怎么找到你们需要的信息。
ACarmona_Intel
 Hello Itsakuya,
Thank you so much for the response.
Please change your system language to English in the meantime while taking the screenshot, since we cannot understand the words that are written on the screen.
Carmona A.
itsakuya
my game:
my Arc750 control panel:
the version 31.0.101.5522  may also crash
ACarmona_Intel
Hello  Itsakuya,
Again, please change your system language to English in the meantime while taking the screenshot, since we cannot understand the words that are written on the screen.
Carmona A.
ACarmona_Intel
Hello Itsakuya,
Thank you so much for providing us with your graphics settings as well as screenshots of your Arc control panel.
We will now do further investigation on the issue, and I will get back to you once I have the updates from our engineers.
Thank you so much for your patience and understanding.
Carmona A.
ACarmona_Intel
Hello Itsakuya,
Thank you so much for patiently waiting on our response.
Please try the latest Arc driver, 101.5534, and check if the crash issue will still occur.
If yes, kindly provide the following additional details in order for us to investigate the issue more deeply:
1. Does the crash happen on saved games only or even on new games?
2. If it only happens on saved games, may we get a copy of your saved game files? Once we receive your saved game files, we will replicate the issue in our lab.
By the way, we advised you to try the driver at 101.5534 since our senior engineers already replicated the issue with Arc driver 101.5534, and we never encountered any crashes.
We look forward to your response!
Carmona A.
itsakuya
I try the driver 31.0.101.5534 for a few days.The crash also happen on new games at 31.0.101.5534.In Chapter 5 of the story,i have met the crash three times.
I guess it may be related to the black screen issue fixed in the driver 31.0.101.5382.
https://community.intel.com/t5/Intel-ARC-Graphics/Ragnarok-Battle-Offline%E6%B2%A1%E6%9C%89%E7%94%BB%E9%9D%A2/m-p/1593025#M13985
I restored the driver to 31.0.101.5333 for a few days too,the crash doesn't happen on saved games or new games.
ACarmona_Intel
Hello Itsakuya,
We are checking in with you to see if you already have the answers to our questions so we can further isolate our issue.
Furthermore, may we know if you have already tried the driver 101.5534?  If yes, can we know the results?
Carmona A.
ACarmona_Intel
Hello Itsakuya,
Carmona A.
ACarmona_Intel
Hello Itsakuya,
Thank you so much for the update, and I'm sorry, as I haven't noticed that you have already replied to me.
Since the issue still persists with driver version 5534, I will raise the case again with our engineers so they can further investigate the problem.
And by the way, we have our latest driver, 31.0.101.5590; please try it again and check if the issue also occurs there, and please keep us updated again regarding the result.
As for the update, I will get back to you as soon as I have our engineers response.
Thank you so much for your effort and patience.
Carmona A.
itsakuya
the driver 31.0.101.5590 may also crash.
As soon as there is an update, I will try it out and give feedback.
thank you very much.
itsakuya
The driver 31.0.101.5592 may also crash.
ACarmona_Intel
Hello Itsakuya,
We have revisited the game with Arc drivers 5593 and 5382 (one of the drivers that is crashing on your system). We have played it for a while, but it still won't crash on us.
In regards to that, please revalidate the game files and do sfc/scannow for Windows, and then try to play the game.
By the way, you mentioned that it crashes only at Chapter 5. So it does not happen in any other chapters?
Furthermore, if possible, can you send us a copy of the saved games you have so we can try to use them? Location is c:\Users\<Windows user name>\ AppData\Local\GBFR\Saved\SaveGames. Have the customer zip the SaveGames folder and send it to us for testing. (*AppData folder might be hidden*)
Thank you so much for all your patience and efforts; we truly appreciate it.
Carmona A.
itsakuya
The driver 31.0.101.5593 may also crash.I also mentioned earlier that it will happen in the mission.But I can't be sure that it only happens in a certain scene.I think it will happen randomly.
I try the driver 31.0.101.5594 for more than 16 hours.It doesn't crash.The issue has been fixed.
Thanks again.
