Intel® ARC™ Graphics
1967 Discussions
Granblue Fantasy Versus game freezes.
DanSun
https://community.intel.com/t5/Intel-ARC-Graphics/Granblue-Fantasy-Versus-game-freezes/m-p/1532737/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufExOTTAzQlg2MVhCSlhUfDE1MzI3Mzd8U1VCU0NSSVBUSU9OU3xoSw#M8849
I was going to post additional information, but Intel ended it, so I'm explaining it again. The reason the game stopped was due to language-related settings. It seems that the game may freeze if you change the game language to Korean settings. The problem is that this symptom occurs only on Intel Arc, and on Radeon and GeForce, problems do not occur due to changing the Korean language of these games. It appears to be a problem caused by changing the Korean language of the game. Since this is a symptom that does not exist in competitor graphics cards, you may need to check this further.
Andres_Intel
Hello DanSun,
Thank you for posting on the Intel communities. I see that your freezing issues while playing Granblue Fantasy Versus with the Intel® Arc™ A770 Graphics (16GB) persist, I know how important is for you to have this issue solved, for us it is really important as well.
We appreciate for keeping us informed when the issue is presented, I will start with the investigation to provide you with the next steps and as soon as I have further information I will let you know
Andres P.
DanSun
I've tested the game, but changing the language doesn't seem to be the problem. I don't know what the cause is. I am uploading the Unreal Engine dump file created due to the error problem I encountered. Currently, it seems that the only way to solve this is to force settings to DXVK and Direct12. It seems that this cannot be resolved in Direct 11, which is the game's default setting.aa.jpg
Andres_Intel
Hello DanSun,
Thank you for the clarification.
We will try to replicate the issue one more time, with the new information you provided, as soon as I have the results I will let you know.
Andres P.
Andres_Intel
Hello DanSun,
Thank you for your time.
We still working on the reproduction, we appreciate your patience, we will have the results soon.
Andres P.
Andres_Intel
Hello DanSun,
Thank you for your patience.
We have been working on the issue replication one more time with your last instructions and it was replicated, we did not face any type of issue related to crashing, graphics corruption or fps drop.
In this case, I recommend you contacting the game developer for further troubleshooting steps.
For now, we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
Andres_Intel
Hello DanSun,
Before I close the case, I want to let you know one more time, that we tried reproducing the issue and worked fine for us even after changing the language to Korean, hence there is something else going on here but if we can't reproduce the issue our developer team won't be able to debug it.
Also, I see the you confirmed running the game in DXVK or Direct12 also fixes the problem. I want to thank you for submitting the feedback to us however we can't promise this will be fixed anytime soon given the low reproducibility rate. As mentioned previously, for now we recommend running the game in any of the listed APIs.
Please let me know if you have further questions.
Andres P.
DanSun
Thank you for your hard work during this long period of testing. I don't know the cause, but I really wanted to solve this problem. It's a shame that I couldn't figure out if it was a computer problem or a specific environment problem, but I'm glad that there is another solution.
Andres_Intel
Hello DanSun,
Happy to hear that, since you do not have further questions, so we will close this thread. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Andres P.
