Intel® ARC™ Graphics
2278 Discussions
I have problems with my Arc A770 16GB on a DIY monitor
Yoshino
I made a portable monitor using a laptop monitor panel. The panel itself supports a maximum of 2560*1600, 240hz, and 10bit color depth, but when connected to the Arc A770 using the Display Port cable, it can only support 2560*1600, 60hz, and 10bit at most.
· I have checked that the cable I am using is DP1.4 standard (it can support 2560*1440, 170hz on other monitors).
· The DIY monitor can support 2560*1600, 240hz, and 10bit on AMD RX6750XT; and 2560*1600, 240hz, and 8bit on RTX 2060.
Diver Version: 30.0.101.5333 (date: 2024 Feb 21)
Does this mean that Arc A770 does not support 16:10 high refresh rate screens at present?
I will attach the Report for Intel® Intel Graphics Command Center and some screenshots of my DIY monitor. (*Please understand that I am using simplified Chinese as the system language, but you should be able to see the specific information in the screenshot.)
RamyerM_Intel
Hello Yoshino
请注意,我们只能用英语为您提供支持。我们使用网络翻译工具来翻译此回复,因此可能存在一些不准确的翻译。
Thank you for posting in the communities. May I please know the model of the monitor panel that you are using? Were you able to test if the same issue applies on different ports as well? When you lower the refresh rate, does the 60hz limit still appear? The reason I ask is because we want to isolate first if it is a hardware issue.
Ramyer M.
RamyerM_Intel
Hello Yoshino
I am just looking for an update regarding the information we requested about your system. Kindly please let me know about this information so we can identify the next steps that needs to be taken to solve this issue.
Ramyer M.
RamyerM_Intel
Hello Yoshino
I hope you are doing well. As we have not heard a response in the past few days, we will proceed in closing this thread. If you need any additional troubleshooting, please submit a new question as this thread will no longer be monitored.
Ramyer M.
