Intel® ARC™ Graphics
3105 Discussions
INTEL ARC 750 + ARC 310
Hashiba
Intento usar las 2 graficas en un solo pc pero no puedo designar programas a cada una, quiero usar la 750 para renders de video y foto y la 310 para streaming en obs y reproduccion de videos pero no encuentro la solucion con windows ni con los controladores de intel
RobbieR_Intel
Hello Hashiba,
Thank you for reaching out. I understand you're facing an issue with designating specific programs to different graphic cards on a single PC. Specifically, you want to use one card for video and photo rendering and the other for streaming in OBS and video playback.
Please generate an SSU report to help me further analyze important details on your system. To generate the SSU report, please refer to the article: How to get the Intel® System Support Utility Logs on Windows*. Please send us the generated SSU.txt file.
Please answer the following questions:
  • What troubleshooting steps have you done?
  • What system are you using to configure the GPU's Settings? Is it IGCC or Arc Control?
  • What is your power supply?
  • Are you using any additional software or utilities that might influence the GPU assignment?
We look forward to your response!
Robbie R.
RobbieR_Intel
Hello Hashiba,
Robbie R.
NormanS_Intel
Hello Hashiba,
We have not heard back from you so I will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Norman S.
