Intel® ARC™ Graphics
3310 Discussions
INTEL ARC 750
Andrey1970
AlHill
Explain your problem in detail.
So the Intel support engineers can have more information about your system, Please download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
[W10 is this generation's XP]
Andrey1970
файл конфигурации приложен к сообщению!!!
AlHill
no configuration attached.
Andrey1970
Texture problem in some games! Not in all!
Andrey1970
Здравствуйте! Что за проблема с графикой в играх? Подскажите решение!!!
Andrey1970
Hello! What is the problem with graphics in games? Tell me the solution!!!
AlHill
Ok, you are going to have to provide much more information rather than just simply keep repeating that there is a problem and asking for a solution,  I have asked twice now for you to provide the SSU report which will provide information on your configuration.
You want help?  Provide the SSU report and explain, IN DETAIL, what the problem is.
Andrey1970
Here I am sending the file again SSU
Andrey1970
There is no such problem on nvidia video cards!
ArchieD_Intel
Hi Andrey1970,
  • Can you please explain more the issue along with the games affected?
  • Does the issue occur only during cutscenes? Or does it also happen during regular gameplay or menus?
  • When did the issue start? Was it after a specific driver update or game patch?
  • What are the troubleshooting steps that you tried so far?
  • Is the Resizable Bar enabled?
  • Have you used DDU to completely remove all residual drivers and installed a new one?
  • Have you tried adjusting the graphics settings?
  • Could you provide a screenshot of your in-game display and graphics settings?
  • Which gaming platform did you use to download the game?
Archie D.
ArchieD_Intel
Hi Andrey1970,
Archie D.
ArchieD_Intel
Hi Andrey1970,
Archie D.
