Intel® Arc™ Discrete Graphics
3633 Discussions
Improve performance Cyberpunk 2077
addelucas123
New Contributor II
Good morning
Once again, the performance of Cyberpunk 2077 is low, with the following settings, Ultra quality + RT activated with ultra quality, I put with Intel 43 and 53 FPS, Far from competing with an RTX 3060 Ti, I could even be at peace or almost at peace with an RTX 3070, The game is updated to the latest version patch 2.02, I checked the files, the drivers were updated, I repeat I uninstalled clean Display Drivers Uninstaller, I installed the latest version of drivers 31.0.101.4952, the performance is low to compete RTX 3060 Ti and I use resolution 1920x1080 144Hz 1ms.
I sincerely ask you to please do once and for all to improve the performance, since the Intel Arc A770 graphics card works better in modern API DirectX 11, Vulkan and DirectX 12, at least Cyberpunk 2077 should improve the performance ok with RT activated quality ultra and the game quality in ultra and activated with fine
Intel Core i7-11700K Stock without overclock
Intel Arc A770 16GB LE
Two DDR4 3200MHz 32GB ram memory modules for a total of 64GB
Windows 10 22H2
Activated Resizable BAR
Andres_Intel
Hello addelucas123,
Thank you for posting on the Intel communities. I noticed that you are having low-performance issues with your Intel® Arc™ A770 Graphics while playing Cyberpunk 2077 with Ray Tracing enabled, I will be happy to help you.
I know that is very important for you to run this game at higher FPS, for that reason I will start with an investigation to provide you with the next steps.
I appreciate for letting me know the steps you have followed, and for providing all the information that is very helpful.
Andres P.
addelucas123
New Contributor II
Remember that the Intel ARC A770 16GB graphics is more powerful than the RTX 3060 and RTX 3060 Ti in teraflops and general raw performance, so in Cyberpunk 2077 with RY activated, with XeSS 1.1 activated quality mode and ultra quality of the game should go 80 to 85 FPS in 1920x1080 resolution, and in 2K 1440p resolution 70 to 75 FPS more or less, so that GPU must far exceed the performance
Andres_Intel
Hello addelucas123,
Thank you for your patience and for your time.
I still working on the replication, it still in progress, we will have the results soon, as soon as I have them I will let you know
Andres P.
Andres_Intel
Hello addelucas123,
Thank you for all your time.
Just for you to know, the Intel® Arc™ A770 Graphicsto have +-10% framerate delta compared to RTX3060 and that Path Tracing is not POR for Alchemist. Only DXR (which Cyberpunk uses for its regular ray tracing) and VK ray tracing are POR for Alchemist.
We understand you have also opened a (chat/email/phone) support case with us, I want to let you know that opening multiple cases for the same issue would generate unnecessary delays. Please avoid opening new community threads and web tickets for the same issue. We will therefore close this community case. Please, keep in mind that this thread will no longer be monitored by Intel, in case that you have further questions, please open a new thread.
Andres P.
Andres_Intel
Hello addelucas123,
Before closing this thread, I want to make sure that you completely understand that the expectation Intel® Arc™ A770 Graphicsto has +-10% framerate delta compared to RTX3060 and that Path Tracing is not POR for Alchemist. Only DXR (which Cyberpunk uses for its regular ray tracing) and VK ray tracing are POR for Alchemist.
Let me know if you have further questions about it.
Andres P.
Andres_Intel
Hello addelucas123,
I just want to remind you the expectation Intel® Arc™ A770 Graphics has +-10% framerate delta compared to RTX3060 and that Path Tracing is not POR for Alchemist. Only DXR (which Cyberpunk uses for its regular ray tracing) and VK ray tracing are POR for Alchemist.
Let us know if you still need assistance.
Andres P.
Andres_Intel
Hello addelucas123,
Andres P.
