Good morning
I wanted to comment and say that the Intel Arc A770 graphics card that I currently have, we would all like to see improved stability and performance in games, especially in DirectX 12. The least demanding games should be a little better Intel Arc A770 vs 3060 Ti at least 6%, I know you are constantly releasing drivers, but I already told you that this graphics card should have 6% higher performance in modern games DirectX 12 triple AAA, I also wanted to please you, I am very bad and I feel uncomfortable, since the Arc A770 has to be the fastest, yes, and with higher frames per second, triple AAA DirectX 12 in the game. For example, when you are going to fix the DirectX 12 issue in Red Dead Redemption 2, use the graphics settings, please quality, it should go to 105 FPS, at least if it can be 1920x1080, Intel graphics or Intel Arc A770 is better than DirectX 12, that's why I want better stability, problem and performance, come on stability and performance, do you know that the specifications of Intel Arc A770 are higher than RTX 3060 Ti, and Intel Arc A750 is higher than RTX 3060, so I don't want an excuse etc that I can't improve performance etc because if I can I don't want to have a problem with your Intel Arc GPU. Once again I ask for improvements in raw performance DirectX 12 triple AAA games surpassing RTX 3060 Ti.
Greetings
David
Thank you for your feedback, as you pointed out we are constantly releasing new drivers with performance improvements and fixing key issues. Regarding your request for the Arc A770 to surpass the RTX 3060/3060 ti our goal is to push performance as high as our hardware can possible yield and time and effort will help us mature our drivers.
Keep your drivers up to date and stay tuned for more updates coming on a regular cadence.
Best Regards.
Ronald M.
Good afternoon
Okay, but remember I'm waiting for DirectX 12 of 1 FPS in Red Dead Redemption 2 with the graphics configuration please quality it should go above all DirectX 12 100 110 FPS, Because if Vulkan goes 85 to 65 FPS some, Well in DirectX 12 it should go 100 to 110 FPS 1920x1080p, Then I also ask that you improve the fan curves when it reaches 78 degrees it should be running 2250 and 2300 with peak 2350 RPM, Then I perfectly understand that you are releasing drivers for performance improvements, stability, etc., but you must keep in mind that the Intel Arc A770 performance is 3% and 6% higher than an RTX 3060 Ti, And the next future of GTA VI unless you can play at high and some ultra things at 60 FPS I don't ask for more, I only ask for that, Please no I want to have a problem with the GPU etc etc. By the way I'm waiting for Days Gone to drop FPS at night and above and below the RTX 3060
Yall should definitely add more options for performance like latency mode, and etc.. i think the gpu would be alot better then. my main concern is resonsiveness and thats what im been looking for without having to buy a much exspensiver card. so far liking the a770 just needs some fixes. i like to play fortnite in performance mode not direct 12 for direct 12 looks weird.
I ask you, if you don't mind, what temperature does the Intel Arc A770 LE graphics card reach? And what box does it use? Because for me it reaches 89 and 90 degrees.
Hello Addelucas123,
We sincerely appreciate your response and your feedback.
In regards to that, as mentioned by one of our moderators, we will continue to enhance our products and drivers. Therefore, it is advisable to ensure that your drivers are up-to-date and remain tuned for regular updates.
Thank you, and have a great day ahead!
Carmona A.
Good afternoon, I'm David, I already have the drivers updated, but the same performance still persists, I hope you fix it soon, Then on the DirectX 12 issue, please improve all the new games, for example Black Myth Wukong, Star Wars Outlaws etc, as you said double performance, that is, Black Myth Wukong, Star Wars Outlaws and other games must run in Ultra with Intel XeSS at least 95 FPS and also activating frame generation that reaches 115 to 120 FPS at least, Intel Arc A770 the 16GB version has power and reaches RTX 3060 Ti please thank you
