Intel® ARC™ Graphics
3474 Discussions
Instant Record need
xshirouu
When will geforce experience and amd have the instant recording feature?
Jean_Intel
Hello xshirouu,
We understand that you would like a feature in the Arc Control Software that you could select a hotkey to save a recording file and be able to change the duration of the recording file you saved. We appreciate you for taking the time to share your thoughts and recommendations which will help to improve the user experience. We will proceed to share the information you provided to the appropriate team, unfortunately, we are unable to commit to an outcome or update about this matter.
We will be more than glad to continue helping you, so let us know if there is anything else we can assist you with.
Jean O.
Jean_Intel
Hello xshirouu,
Thank you for posting on the Intel️® communities. We would be more than glad to help you with your issue. However, we would like to gather more details about your issue, are you looking for a recording feature, similar to the options in the Geforce experience and AMD?
Best regards
Jean O.
xshirouu
Yes, I'm talking about a feature just like that "highlights" is not automatic, it's the kind of thing that is connected to a hotkey and we can adjust its duration, I think such a feature should come as soon as possible
Carlos_C
Intel Does Have Capture in the studio tab of Arc Control, but it's absolutely terrible in every way; Audio is off-sync, recording is in 30fps and you cannot map hotkeys at all in the Settings tab.
Just use  Open Broadcasting Software(OBS)'s replay buffer if you need to capture short clips, but make sure you got plenty of RAM.
Jean_Intel
Hello xshirouu,
Jean O.
Jean_Intel
Hello xshirouu,
Since we have not heard back from you, we will proceed to close this thread. We want to thank you for sharing your feedback on this thread.
If you need any additional information, open a new question, as this thread will no longer be monitored.
Jean O.
