Intel® ARC™ Graphics
968 Discussions
Intel ARC Control overlay won't open - latest A380 31.0.101.3277 drivers installed
dkirwan83
I noticed Intel ARC Control would break on a machine featuring the ASRock A380 dGPU with multiple user logins and demand to be reinstalled/repaired with each new login as it seemingly doesn't configure itself as a system-wide app.
I deleted the only other user account on this machine and did several clean reinstalls of the latest 31.0.101.3277 ARC driver, but the overlay no longer appears with Alt+I or running the app shortcut directly from the start menu. No errors occur. Simply nothing happens after a minor amount of SSD activity.
Intel SSU attached.
dkirwan83
For anyone who cares...
The solution was to remove PARSEC - the remote-play app. It uses a synthetic/virtual display adapter that seems to have been interfering with the dGPU driver.
I removed PARSEC, rebooted and now my ARC Control overlay works fine again /shrug
dkirwan83
v12dock
Is there an ETA on a fix for this issue. When you are using Parsec and open the Intel Arc Control overlay it crashes Parsec. This is not an acceptable solution.
